Old 06-22-2020, 06:34 PM   #1
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
Brake fluid color indication of tracked?
Looking under the hood today and noticed the brake fluid is pretty dark for only 5500 miles. I bought the car used at around 3200 and I have never tracked it. Would the dark color indicate the previous owner tracked it? One pic with flash one without. Thanks.
getchapull is offline   Reply With Quote
Old 06-22-2020, 06:41 PM   #2
Techdude99
Techdude99's Avatar
Drives: 2019 Chevy Camaro ZL1 1LE
Not necessarily. Get a brake fluid tester. I use this one: https://www.amazon.com/dp/B005HVG4GQ..._tnt8EbA51RB2Z
Techdude99 is offline   Reply With Quote
Old 06-22-2020, 06:49 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
nope but if it looks like gravy id replace it lol
Old 06-22-2020, 07:13 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Any brake fluid which looks like that deserves to be flushed immediately
Old 06-22-2020, 07:16 PM   #5
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Can't say for sure, but my guess is that stuff got very hot, very likely from some hard tracking... I've seen 8 year old, 60,000 mile fluid look way better...
Change it ASAP...
Old 06-22-2020, 07:23 PM   #6
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Definitely looks like it has been heated up. I wouldn’t worry over the car having been tracked. That doesn’t mean it has been abused. These cars are designed for it.
CW3SF is offline   Reply With Quote
Old 06-22-2020, 07:27 PM   #7
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
I’ve been tracking cars since 1989 and I’ve never seen fluid in the reservoir discolor like that. Was that in the 2019 ZL1? That looks like 5 year old fluid to me.
m3bs is offline   Reply With Quote
Old 06-22-2020, 10:13 PM   #8
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
Some fluids grow darker faster than others. Most of the time the fluid will be darkest in the lines near the calipers as it sees the most heat. This typically looks dirty and aged so best be safe to just change it anyway.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 06-22-2020, 10:37 PM   #9
Stephen12ZL1
Drives: '21 ZLE A10
oh...before anyone flushes that disgusting fluid out of the system, please use a baster or equivalent to suck out the reservoir contents. Add fresh fluid then proceed.
Old 06-22-2020, 11:03 PM   #10
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
This car driven hard on track cooks the fluid fast.
SFV1LE is offline   Reply With Quote
Old 06-22-2020, 11:06 PM   #11
supersportss
Drives: 2019 SS
its normal caused by water intrusion, change it out you'll be fine.
supersportss is offline   Reply With Quote
Old 06-23-2020, 07:39 PM   #12
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
I'll use a vacuum brake bleeder. Suck out the reservoir 1st, then work on the bleeder screws.
So the order of suckage is furthest away from reservoir to closest like most vehicles? Anyone know the size of the bleeder screws?
Any tips for this car from the pros?
Thanks.
Old 06-24-2020, 03:01 AM   #13
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
To be honest my Motul DOT4 fluid on both the SS 1LE I had and my current ZLE usually look like that and I don't have any braking issues on track with stock pads. I flush the fluid twice a year or so.
When I did my own flushes usually the color was orange coming out of the calipers and after a couple seconds it turned the normal clearish yellow. The reservoir was similarly orange. But I think you also will see that the color of the reservoir is also darker because you are looking through a fairly deep section which will look darker than if it came through a narrow clear tube.
I'd flush it if it's unknown and it bothers you, but I bet you will see it discolor pretty fast once again.
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green)
Previous cars:
- 2018 Camaro ZL1 1LE (Red Hot)
- 2018 Miata RF GT (Machine Gray/Auburn)
- 2017 Camaro 1SS 1LE (Summit White)
- 2008 BMW 135i (Montego Blue)
- 1996 BMW 328i (Arctic Silver)
R3ctivision is offline   Reply With Quote
Old 06-24-2020, 11:43 AM   #14
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
Maybe the color gets darker faster because of clutch usage?
