![]() Drives: 2013 ZL1 Join Date: Dec 2015
Trade
Thinking of trading my modified 2013 for a 2013 GT-R Black?
'Maro
Drives: 2015 SS 6.2L Auto 2SS Join Date: Sep 2016
Mmmkay
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
Shred Till I'm Dead
Drives: 2013 ZL1 Summit White Join Date: Aug 2016
Don't do it!!!!!!!!!!
2013 Summit White ZL1 W/Recaros
Mods: Roto-Fab CAI, Stainless Works 3" Exhaust, 1-7/8" Stainless Works LT Headers, 2.55 Griptec Upper, Metco Damper, 9.1" Metco Lower Ring, Metco Solid Isolator, Metco Idler Relocation Bracket/50mm Idler, Texas Speed Heads/Pushrods/Springs/Retainers/SS Valves/Custom Grind Cam, ARP Bolt Kit, DMS Auxiliary Fuel Pump Kit With Flex Fuel Sensor, ID1300 Injectors, Lingenfelter Dual Fan HX, Lingenfelter 160 Degree Thermostat, DMS Expansion Tank Tuned By Matt at Dedicated Motorsports - 750whp on E85 - Mainline Hub Dyno |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I say go for it. It sounds like you have had the itch for a different ride for some time now.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
![]() Drives: 2012 ZL1 Join Date: Apr 2015
I have the same thought from time to time, I cant blame you !! I'd say do it and make it a beast!!
2012 ZL1 preproduction car #13 ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Don't get rid of your Z. Plenty of folks on this forum have had sellers remorse. If you can swing it, own both and do your own comparison and after a year or so keep the car you like better. I know this is easier said than done financially.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 1SS 1LE Vivid Orange Join Date: Mar 2011
The guy with the mustang is way more excited.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
