Old 06-20-2020, 04:42 PM   #1
Muskiehunterman
Camaro Time
Muskiehunterman's Avatar
Drives: 2021 Camaro 1SS/1LE
10L90 vs 10L80 Gear ratio.
I am moving from a 2020 Camaro SS to a 2021 1LE with the 10 speed transmission. Where is the 10L90, 2.85 ratio different than the 2.77 ratio of the 10L80. I understand the duty rating difference, I am just having trouble finding all the gear specs to compare. Any help would be greatly appreciated.
Muskiehunterman is offline   Reply With Quote
Old 06-22-2020, 11:18 AM   #2
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
The SS1LE is not going to get the 10L90, it will have the same 10L80 as your current car and the gear ratio you are referring to is the rear differential ratio not the transmission.
Old 06-22-2020, 09:40 PM   #3
Here's what GM authority showed. All the same but I'm not sure I trust the 10L80 numbers.
Old 07-05-2020, 09:31 PM   #4
Muskiehunterman
Camaro Time
Wish I knew
Given info that indicates 10L90 Is paired with the 2.85 rear gears, but found no clear info when I looked. My dealer May have led me astray, could be 10L80, which is not a bad thing. I had the 10L80 on my 2020 SS and it rocked.
Old 07-06-2020, 10:57 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The SS 1LE does not get the 10l90...only the ZL1 does. However the 10l80 equipped SS 1le does get the same ELSD differential with 2.85 gears as the 10l90 equipped ZL1.
Old 07-07-2020, 09:04 PM   #6
Muskiehunterman
Camaro Time
1LE Transmission
Thank you for the info. I couldn’t find anything,
Old 08-10-2021, 12:47 PM   #7
YoungFamous
Amos6.2Jr
Drives: 21 A10 2SS 1LE
So is the ss 10l80 2.85 rear ratio too?
YoungFamous is offline   Reply With Quote
Old 08-10-2021, 02:47 PM   #8
No, only for the 1LE. Gear ratios are the same, but the final drive ratio is 2.77 on the SS (10L80) and 2.85 on the ZL1 (10L90) as well as the SS 1LE (10L80).
Old 09-01-2021, 03:07 PM   #9
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Damn I wish I got here earlier
https://www.camaro6.com/forums/showthread.php?t=584316
2016 1LT v6
- Totaled
Happiness: Infinite
