Old 06-17-2020, 06:28 PM   #1
G61LE
G61LE's Avatar
Drives: 2019 Camaro ZL1 // 1LE
How are you guys tying down your ZLE on the trailer
I have a 2019 ZL1/1LE that I take to HPDE's. My previous track day car was a Z06, which have the frame slots for the T-hooks and straps. BUT, I guess GM didn't think we needed them on the ZLE, so I have been using the "over the tire" straps, tied down to the side of my open trailer. It works, but it is a pain in the butt because there is not enough room to fit my arm in the wheels wells to make sure the straps are securely behind the tire/rim, plus, if and when I pull my car onto the trailer after my last session to go home, the tires are hot as hell and it makes it even more fun to tie down. I just installed theZL1 Addons ZL1 tie down hooks on the car and was wondering if anybody else has used them and has either good or bad results... Does anybody tie down through the wheels ? I have heard that doing that can yank the car out of alignment.
G61LE is offline   Reply With Quote
Old 06-17-2020, 06:30 PM   #2
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
I'm using the ZL1addons tiedown hooks for the front, and just running axle straps through the opening in the subframe in the rear. I haven't tried the zl1addon hooks for the rear yet.
rotis is offline   Reply With Quote
Old 06-17-2020, 06:46 PM   #3
Badmojo
aka BeastZL1
Badmojo's Avatar
Mac's Tie-Downs
I give these through-the-wheel straps the highest possible recommendation. Simply awesome. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 06-17-2020, 08:01 PM   #4
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
Originally Posted by Badmojo View Post
Mac's Tie-Downs
Same as I just got for mine. Except I paid too much......
m3bs is offline   Reply With Quote
Old 06-17-2020, 08:38 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I use the ZL1 add-ons front and rear tow hooks and they seem to work fine. I have trailered at least 25 times with them and I've never had an issue. The rear hooks have rotated a little bit once or twice.
Old 06-18-2020, 07:46 AM   #6
ICTsccaCamaro
Drives: 2018 ZL1 1LE
IMO the best and only way to tie down a vehicle on a car trailer is with E track and wheel straps if you are tying the vehicle down from the chassis or body you are compressing the suspension and putting bushings and other suspension components under stress or in a bind at all times while towing, with the wheel straps you are only holding the wheels down to the trailer surface and allowing the suspension to float and move as it would if the vehicle was being driven down the highway, all major car transport companies used this same method that has to tell you something right there.
ICTsccaCamaro is offline   Reply With Quote
Old 06-20-2020, 09:26 AM   #7
Rodan
Drives: 2018 ZL1 coupe
I use the same setup... Mac's over the wheel straps to E-track.
The only thing is it's a PITA with an enclosed trailer... not a lot of room on either side of the car. And you need to make sure you have enough E-track to get the ratchet out from under the front/rear of the car.
We hauled our ZL1 about 5k miles last summer on a cross-country trip and never had any issues.
Rodan is offline   Reply With Quote
Old 06-20-2020, 07:04 PM   #8
G61LE
G61LE's Avatar
I would love to go the E-Track route, but I have an aluminum open trailer. I have heard steel on aluminum causes some kind of corrosion issues. Has anybody bolted the E-Tracks to their aluminum trailer. According to E-Track they recommend bolting to directly to the frame, but the frame is along the middle of the trailer...
Old 06-21-2020, 01:59 PM   #9
ICTsccaCamaro
One of our local Z06 guys has a aluminum trailer with the e track with no issue
Old 06-30-2020, 03:36 PM   #10
Max2075
Max2075's Avatar
Drives: 2004 Z06, 2018 ZL1 1LE
I use straps about 1.5 feet long, axle straps, and rout them around the front sub-frame at the back of the sub frame in front of the back mounting point. Then run the front straps diagonally. On the rear, I run axle straps through the bracket that attaches the body to the rear sub frame in front of the rear tires tires. I had to remove the inner fender screw to this bracket for this to work. I run the straps diagonally also. This worked great for my last trip that was over 3000 miles. It is a pain to tie it down initially but east to undue. I have an aluminum trailer and I have to tie the car down towards the rear of the trailer for proper hitch weight. There is no room for the e tracks in my case.
Max2075 is offline   Reply With Quote
Old 09-13-2023, 09:40 AM   #11
Thestormoverkrynn
Drives: Camaro Zl1
how big is your trailer?
Thestormoverkrynn is offline   Reply With Quote
Old 09-13-2023, 07:19 PM   #12
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
I have a 18ft aluma trailer that I put etrack on. It was a bit tricky because I had to get longer bolts to get all the way through to the backing plates, but it's solid. You do get etrack prints on hot tires, but they go away after you warm them up again.
eimarshall is offline   Reply With Quote
