Old 06-17-2020, 05:47 AM   #1
IneedAZ
IneedAZ's Avatar
Who has changed the heads or ported theirs?
Decided this needs a new thread. Curious if you had yours ported or replaced. I am on the fence. How much gain from porting? How much from New castings? Was looking at the Texas Speed heads or to do the porting.
I know probably not needed for my 750-800rwhp goals, but since it is apart it is now or never. I am adding a BTR Stage 2 and a 2650 all on 93.
Old 06-17-2020, 10:36 AM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Tune Time Performance ported mine on the 5-axis CNC machine. They were coming off and it was one of those "while we are here" things.
Old 06-17-2020, 11:19 AM   #3
IneedAZ
IneedAZ's Avatar
what other mods? Porting seems to be in the $900-1200 range opposed to a set of custom heads in the 2800-3000 range. But dont see any post or claims of what power to expect from either. Not sure $3000 for 35-40hp is worth it. Perhaps it is a higher gain, but no idea.
Old 06-17-2020, 01:25 PM   #4
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Powertrain mods:
Roto-fab CAI - Dry
Kaitech 103mm TB
Magnuson TVS2300 for LT4 w/103mm upgrade
Ported Stock Heads by Tune Time Performance in house 5-axis CNC
Stage 2 LT4 Cam
Upgraded valve train (phase lockout, AFM delete valley cover, lifter trays, ARP head studs, lifters, timing chain, valve springs, pushrods, etc)
ARH 1-7/8" LT headers (Swain Tech coated)
3" Borla Exhaust
JMS FuelMax
Old 06-17-2020, 04:32 PM   #5
IneedAZ
IneedAZ's Avatar
When u finished your build what were your hp results? 93 octane car?
Old 06-17-2020, 04:43 PM   #6
Bohanan23
Drives: 2016 Camaro 2SS A8
From Pray's research he doesn't see any justification in aftermarket castings with how well companies are porting the stock castings. I would have GPI or TSP port your stock heads and you can pocket the $4-5k you'll save from aftermarket castings
Bohanan23 is offline   Reply With Quote
Old 06-17-2020, 04:54 PM   #7
IneedAZ
IneedAZ's Avatar
I am trying to justify doing the porting as well. Is there enough to be gained for the $1k and 2 extra weeks of the car being down. I'm led to believe there is only 15-30hp to be gained.
Old 06-17-2020, 05:41 PM   #8
Flowtie1
Drives: 2017 ZL1
30 rwhp is well worth 1k to me
2017 ZL1 M6 Silver Ice Metallic
Flowtie1 is offline   Reply With Quote
Old 06-17-2020, 05:46 PM   #9
IneedAZ
IneedAZ's Avatar
Not sure I will be running enough boost to get the 30 out of them. I am thinking of running 15% lower with the 90mm upper all on 93. One of my biggest issues is the 2 extra weeks of down time.
Old 06-18-2020, 08:16 AM   #10
SONiC MOjO
Drives: 2018 Zl1 A10
One thing porting does, people don’t think about is the flow and efficiency of it.
Not only couple extra Hp which is nice. Say you have 700hp at 14psi stock heads,
You can get 720 at 12psi on your ported heads. Less strain on your valve train and motor. Well worth it if you already have the heads off. ����
SONiC MOjO is offline   Reply With Quote
Old 06-18-2020, 08:24 AM   #11
Bohanan23
Power is in the heads.. If you're doing a cam you might as well anyways. Efficient combo! Make more power with less effort
Old 06-18-2020, 08:34 AM   #12
Juiced1
Drives: 2012 2SS CAMARO 45th
It's generally worth about 25-30rwhp. The only problem is it's a big job just to do the heads. So if you're doing the cam its a great time to get the heads done.
About $900 for the port work or you're paying big bucks for new castings and port work. Just depends on how long you can deal with the car being down. If you drop the money on the castings you can always sell your stock heads later. They are worth good cash
Juiced1 is offline   Reply With Quote
Old 06-18-2020, 10:42 AM   #13
Choda
Drives: Turbo 6.2
i got mine ported while i had then off for the same "might as well". I have no idea if it gained me any power because I changed so much.
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 06-18-2020, 10:48 AM   #14
IneedAZ
IneedAZ's Avatar
who did yours?
