Old 06-16-2020, 01:17 PM   #1
dagoldsmith286
RealDannyG86
dagoldsmith286's Avatar
Drives: 2016 Camaro Coupe 2LT+RS (M6)
Edelbrock Supercharger + Cold air intake?
Im trying to do some research... Edelbrock has been making a Supercharger for the v6 Camaro for a year or 2 now but I haven't seen anyone using a Cold air intake with this set up? Why is that the case? Iv seen the Procharger kit using the GM Performance intake along with the the super charger? Iv also talked to a Edelbrock dealer who told me the instructions say use the factory air box because of the tubing and tune are set up for that set up but why can't we just extend or fab the tubing to fit a cold air intake? Any thoughts?
dagoldsmith286 is offline   Reply With Quote
Old 06-16-2020, 02:44 PM   #2
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
It is because of the new location of the throttle body. The factory throttle body location is almost dead center of the engine, the Edelbrock set up has the throttle body off to the Passenger side.
So that makes most aftermarket intake tubes not long enough to reach the new location of the throttle body. A new tube would have to be made, that is typically something that most intake manufacturers will not do unless they see a large demand for it.
You could potentially adapt the supplied Edelbrock tube to the intake box that you have. This would be accomplished a bit easier then getting a new tube made.
Now as for the tune. Edelbrock designed the kit to work with the factory box, so their files are calibrated for the factory box. There would be a minimal change to the file if an aftermarket box was in place. Its not much but in order for them to get those systems CARB approved they have to create calibrations with the factory box.
ProCharger is able to adapt it cause of the way they route their tubing and the test car they used already had the intake on it. Since it was a GM intake kit the location of everything was going to be the same as the factory box, if not then they would be using the factory box to design the kit.
I hope this answers your questions.
Thank you,
Ricardo
Sales@Phastek is offline   Reply With Quote
Old 06-23-2020, 08:42 PM   #3
dgriff14
waddupdgriff
dgriff14's Avatar
Drives: Supercharged 2016 2LT RS
I think it’s almost been around a year since they came out with the kit for our cars. I have it and I have a post or two about it. I “Swiss cheesed” my air box to try to allow more air in, but I believe Will and I are going to work on maximizing flow and upgrading my air intake system entirely.
2016 Chevrolet Camaro 2LT RS
• Edelbrock E-Force Stage 1 Supercharger • Custom tune by Overkill Motorsports • AFE Momentum GT Pro Dry Cold Air Intake • MBRP SS Cat Back Exhaust • iROC-z Wheels • Nitto NT555 G2 Tires (275 fronts, 305 rears)
dgriff14 is offline   Reply With Quote
