Old 06-14-2020, 12:02 PM   #1
federal
federal's Avatar
Drives: 2019 ZL1
MM wild catch can install verification
Hey all,
Just wanted to verify with others who have a similar setup that I did indeed install my MM wild catch can correctly before I get on it too hard and end up hurting any seals or anything...
On the right side of the throttlebody, there are two ports that I remover the original hard plastic line from. I have the lower one capped off with the provided cap, and then then smaller vacuum hose connected to the top port which runs to the corresponding port on the catch can. I then have the thicker line running from the oil cap replacement to the corresponding larger port on the catch can.
Based on all the posts I’ve seen and the instructions, this is correct for a boosted setup. Does this sound about right from everyone? I know for sure the oil cap line is setup correctly, but I’m just making sure it is indeed the upper port that needs to have the line running from it, and having the bottom one capped off, instead of the other way around.
Image for reference - I have the line from the catch can going to the PCV return, and the lower valley port capped off:
2019 Camaro ZL1
federal is offline   Reply With Quote
Old 06-15-2020, 07:03 AM   #2
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Correct!. The top PCV Return is your vacuum source and should connect to the Wild MM Can (fitting is opposite side of sight glass). The Valve cover connection runs over to the large AN fitting just above the sight glass on the can.
Dysan911 is offline   Reply With Quote
Old 06-19-2020, 03:00 AM   #3
Mikemanzo13
Mikemanzo13's Avatar
Drives: 2016 Camaro 2ss
[IMG][/IMG]
this may help
New setup msd intake manifold, 95mm throttle body, flex fuel senor, bbk long tube catless headers, mbrp x pipe and mid pipes, awe axle back, p1x procharger kit
with stage 2 intercooler and race blow off valve, lt4 injectors, hpfp, low side fuel pump, mighty mouse catch can, baro breakout harness
waiting for the tune
Old setup msd intake manifold
95mm throttle body, flex fuel sensor, roto fab intake,
dyno number 500whp on e85
484whp 93
Mikemanzo13 is offline   Reply With Quote
