06-11-2020, 08:23 AM | #1 |
Drives: 2016 2SS Join Date: Mar 2019
Gravedigger differential question
Where do I find out more about this rear end. It was made from a gen 5 rear end to fit a gen 6 car. Anyone know about these parts?
06-11-2020, 10:45 AM | #2 |
Some explanation. I would like to change the rear gear in my car and there does not seem to be anything available for the gen6 cars. I stumbled on this Gravedigger thing and thought maybe it might be a solution. Might be cost prohibitive. I would like to put a 3:42 or 45 in place of 2:77s. It would still be OK for the street and way better for the drag strip.
06-11-2020, 01:21 PM | #3 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
How much power are you making ?
06-11-2020, 01:27 PM | #4 |
06-12-2020, 05:17 PM | #5 |
Drives: like an old lady Join Date: Jun 2012
doubtful. these cars car in the 1.2s on the stock rear gear.
06-12-2020, 09:32 PM | #6 |
06-14-2020, 08:41 AM | #7 |
He's talking about 60' times at the drag strip. You'll be wasting money changing gears in my opinion.
06-14-2020, 10:10 AM | #8 |
He is saying you are looking in the wrong area to go faster. Plenty of other things to consider instead of gears. The 5th gen also had a A6 trans...it's gearing was not nearly as aggressive as the A8.
2016 NFG 1SS A8
06-15-2020, 12:22 PM | #9 |
You are probably rite. The final drive ratio would be way deep.
07-02-2020, 07:10 AM | #10 |
The Grave Digger is the 5th gen ZL1 diff and it is a heavy beast. I could barely lift one.
:( And I am not sure if there are any other gears besides the stock ones. 3.23 and 3.73. That's it I think. But compared to aftermarket diffs they are a good deal but sort of useless. OP you do not need a stronger diff. And not many useful gear choices for CA6 Camaros.
07-03-2020, 05:21 PM | #11 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Smaller diameter wheels artificially changes gear ratio
17" racestars would probably give you the feel you're looking for
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
07-04-2020, 08:38 AM | #12 |
I decided a couple of weeks ago that a gear change is not the way to go. I am now looking at intake manifold and E85. Thanks to all for the input.
07-05-2020, 01:53 PM | #13 | |
They will also push you towards LTs. I did that on my 2016 SS. But I will avoid that on my LT1. It sounds too good right now to spend all those $$ and ruin the sound and only pick up 15 or so HPs. But even with your plan you will feel the difference for sure. I did the E85 on my 16 but is PIA to keep up the E content. But having a good percentage will give you Camaro an extra kick.
