![]() Drives: 2018 1SS 1LE Join Date: Jul 2012
Power guess?
Car is going to Livernois for LT4 injectors, LT4 HPFP, 160 degree t-stat, 3 bar sensor and tune. Just curious on power level estimates. What should/can I expect?
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
Around 650 if running e85
No e85....that’s next round of mods. 93 fuel.
Moderator
Not sure how you’re pullied or how much boost you’re making...but I’ll go 600 on 93 assuming 8-9 psi.
Good point....7lbs pulley.
More then you have now.
#7 |
Moderator
So probably 560-580 on 7 lbs I’d guess.
#8 |
#9 |
![]() Drives: 2018 SS 1le Join Date: Aug 2018
I made 620 with the p1x plus full cat deletes so I'm going to guess 585 whp.
*Procharger P1x w/ stage 2 IC and big red BOV* Full LT4 Fuel System* New Era Performance cat delete pipes* MM Wild catch can* AWE touring axel back exhaust *P3 multi gauge *ACS composite Zl1 side skirts * Zl1 1le painted flowtie
#10 |
585 will make me happy....I can live with that.
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro V6/RS Join Date: Nov 2018
Just so you know, Livernois has both a Dynojet and a Mustang Dyno. I've been there many times, and seen numbers vary a lot. Just wanted to throw that out there to you
#12 |
Thanks....I’ve been there a lot too. They did all the work on my G8 back in the day.
#13 |
Good deal. It's been a little while, but do you know a tech there named Colin by chance? Him and I used to have some grudge matches back in the day. Me in my built LS1 Camaro, and him with a built terminator Cobra. We've raced like a dozen times or more lol
#14 |
Name isn’t ringing a bell.
