Old 06-09-2020, 07:42 PM   #1
Tank22
Drives: 2020 Camaro ZL1 1LE
Question Bridgestone Potenza S007 HELP
Has anyone used the Bridgestone Potenza S007 in Time Attack or SCCA Time Trials... or even just on a track day? That's all I can source last minute.
I didn't realize I can't use the OEM Tire in SCCA without being dumped into Unlimited which is absolutely ridiculous.
if these tires completely suck I wont bother spending the money and I'll just drop into unlimited.
*****VERDICT: THEY ARE AWEFUL. NO GRIP. JUST TERRIBLE
Tank22 is offline   Reply With Quote
Old 06-09-2020, 09:09 PM   #2
Techdude99
Techdude99's Avatar
Drives: 2019 Chevy Camaro ZL1 1LE
Never used them because I don't do time attack, but I did a Google search and they should do well.
Techdude99 is offline   Reply With Quote
Old 06-10-2020, 06:23 AM   #3
CasualGuy
Drives: '19 ZL1 1LE | ‘19 MX-5 Miata 30AE
I’ve run Bridgestone RE-11s (the predecessor to the S007) on both a C6 and a GT350 I owned previously and liked them. Grip was a slight step up from the Michelin Pilot Super Sport of the day, so I would think the S007 would be in the ballpark of today’s Pilot Sport 4S. Longevity/treadwear will be FAR superior to your OEM Goodyear 3Rs (I corded one of my fronts in ONE DAY of hard track driving).
IMO, the best 200+TW ZLE tire for time trials/autocross is the Goodyear Supercar 3 (non-R) if you can get a set. I’ve been running them this year, and they’re really good.
CasualGuy is offline   Reply With Quote
Old 06-10-2020, 07:47 AM   #4
ICTsccaCamaro
Drives: 2018 ZL1 1LE
Bridgestone RE-71r is going to be the tire you want for 200tw
ICTsccaCamaro is offline   Reply With Quote
Old 06-10-2020, 12:08 PM   #5
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
The S007A is a step below the RE-71R.
Old 06-10-2020, 04:54 PM   #6
Road Pressence
Road Pressence's Avatar
Drives: 2019 Satin Steel ZLE
I've only used them on the streets and back roads but really like them and they do offer pretty good grip.
Road Pressence is offline   Reply With Quote
Old 06-10-2020, 06:41 PM   #7
Tank22
Thanks for the feedback. I am told the RE71 does not come in a 325/30/19. I'm going to try them out and see what I can get. I tried to get Supercar 3's and Cup2's but no luck in my area.
Old 06-11-2020, 07:04 AM   #8
CasualGuy
I used to think so as well and have run many sets of RE71R on several different cars. And if a 325 rear was available for the ZLE they would probably still be the best tire for TT/autocross. However, the SC3s are available in 325 widths, and I’ve found they much better suit our cars. I swapped from 305 RE71Rs to OEM fitment SC3s for this season of autocross and track use and have found noticeably more grip from the Goodyears.
Old 06-15-2020, 05:13 PM   #9
Tank22
Thank you for the responses. The S007's were terrible.... Terrible cold, terrible warm and like driving on grease when hot. There was a Yokahama Tire Engineer at the track who was able to take tire temps for me which were only 20 degrees varied from inside to outside. Given the super long front straight he said the setup was great. The tires just don't work for this car on track. This was an expensive lesson...
Old 06-16-2020, 11:42 AM   #10
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
If you are comparing them to the G3Rs, that's a no brainer that they were that bad. Have you run any other 200+TW tires on the car?
Old 06-16-2020, 01:39 PM   #11
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Plenty of Cup2 s on Tire Rack and should be delivered to you with 2-3 days max. Cup2s come in sizes you want like 305/325, I run 315/30/19-F, 345/30/19-R on my ZLE. You do want to relocate the drivers side rear wheel well wiring harness but only takes 45-60 min. and other than that they fit great under heavy track use.
SFV1LE is offline   Reply With Quote
