Old 06-08-2020, 10:37 PM   #1
EJR8402
EJR8402's Avatar
Drives: 2019 Red Hot 1SS "Scarlett"
Launch Control Doesn't Work
And by doesn't work I mean the system simply won't engage. I put it in track mode, stabilitrak, etc and it shows me "apply brake." At this point, when you apply the brake it's supposed to show the bar filling up, similar to line lock, but this doesn't happen at all.
Anyone else experience this? Is there a solution other than taking it to the dealer?
EJR8402 is offline   Reply With Quote
Old 06-09-2020, 12:14 AM   #2
crosive
Drives: 18 zl1
how hard are you applying the brake? you have to apply it *hard*, like almost standing on it (at least that's what I had to do in my 17 ss and 18 zl1)
crosive is offline   Reply With Quote
Old 06-09-2020, 03:29 AM   #3
CoeusAscended
Drives: Chevrolet Camaro SS 2018
Don't apply your brake, stomp your brake, and try again.
CoeusAscended is offline   Reply With Quote
Old 06-09-2020, 06:25 AM   #4
DrHolliday
Drives: 2019 Camaro 2SS A10
It works in my '19. but the bar doesn't fill. Just push the brake to the floor hard, then stab the throttle to the floor. it will hold rpm's about 2k unless you adjust it.
DrHolliday is offline   Reply With Quote
Old 06-09-2020, 11:31 AM   #5
EJR8402
EJR8402's Avatar
Thank you, I'll try that...strange that the bar wouldn't fill up like I've seen on videos.
Old 06-09-2020, 11:32 AM   #6
EJR8402
EJR8402's Avatar
I was applying it pretty d@mn hard. If it works without the bar filling up, that would explain it.
Old 06-09-2020, 12:24 PM   #7
ride_002000
Drives: 2016 F150
I thought mine didn't work either and felt I was pressing very hard on the brake but take above advice and stomp on the brake.
ride_002000 is offline   Reply With Quote
Old 06-09-2020, 02:31 PM   #8
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I thought the same thing on my 2020 2SS... The bar does NOT fill up on launch control (you would think it should by the way it looks, but it doesn't).
Step on the brakes like a panic stop then jam the throttle hard (my first couple tries I eased in the throttle and it didn't work, way exceeded 2000 RPM). You have to stab the throttle to the floor and it will work, let it stabilizer at 2000 and quickly release the brakes and hang on!
Old 06-09-2020, 03:35 PM   #9
EJR8402
EJR8402's Avatar
Ok- I'm glad something isn't messed up. Looking forward to trying this!
Old 01-09-2022, 05:28 PM   #10
Sayykidd
Drives: 2020 camaro ss
Thanks man !! I thought mines didn’t work either 😂😂
Sayykidd is offline   Reply With Quote
Old 01-09-2022, 09:21 PM   #11
flobb
Drives: 2022 2SS
I have to admit I made a pretty stupid mistake the first time I tried line lock. The car was in Park. I was stomping the crap out of the brake trying to figure out why it wouldn't engage.
flobb is offline   Reply With Quote
Old 01-10-2022, 06:43 PM   #12
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Hey 2SS Capt, would you know if the base LT1 has this option as the car has no track mode?
lt4camaro is offline   Reply With Quote
Old 01-10-2022, 07:03 PM   #13
ZL1plumbin
Drives: ZL1 1LE on order
Never thought about it until now but do the manual trans cars have launch control also?
ZL1plumbin is offline   Reply With Quote
Old 01-10-2022, 07:11 PM   #14
lt4camaro
lt4camaro's Avatar
Auto trans cars only.
