Old 06-06-2020, 11:12 PM   #1
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Wheel Bearing And Hub Assembly
Question... is there an aftermarket "performance" upgrade available to choose, or are we limited to the OEM replacements? I am noticing a little resistance in free spin, the left (front) drag is more prominent (caliper and rotor off). Probably may be looking to replace them in the near future. Idk
driven2exceSS is offline   Reply With Quote
Old 06-06-2020, 11:56 PM   #2
TrackClub
TrackClub's Avatar
SKF makes race grade hubs. I had them on my C5Z.
Unsure re Camaro fitments etc.
If a hub goes it usually makes a noise when driven on and the wheel would have a play when tested on a lift?
Unsure what your symptoms point to.
I am sure others will chime in with first hand experience as i have none here. Good luck and cheers!
Old 06-07-2020, 10:14 AM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
The SS 1LE has the SKF x-tracker hubs from the factory; not going to get much better than that. If you have to replace, I'd go that route.
But, as trackclub mentioned, you don't necessarily need to replace right now. Just keep an eye on it and check for lash (i.e. hub moving inside the knuckle) and noise. Slight differences in drag aren't show-stoppers.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 06-07-2020, 11:01 AM   #4
driven2exceSS
Thank you both... Alpha1BC any idea if the SS 1LE hubs are a direct fit to the regular SS when the time comes? Maybe you are already implying they do. But want to double check.
Old 06-07-2020, 12:07 PM   #5
TrackClub
TrackClub's Avatar
How! What a nice surprise GM put top of the line parts there. Impressive! Thx for sharing the info. Cheers!
Old 06-07-2020, 07:18 PM   #6
Alpha1BC
Alpha1BC's Avatar
Did some digging, turns out all 6th gen Camaros have the same hub/bearing assemblies: 13512895 on the front and 13512894 on the rear. This means that all 6th gen Camaros have the x-tracker hubs, not just some of them.
And yeah! Was doing some digging to see if SKF sold the x-tracker hubs for the 1LE since a friend of mine has had good luck with them on a few of his track cars (I like to know what parts are available for when replacement time comes), but was pleasantly surprised to find it already has them!
2017 SS 1LE.
Old 06-07-2020, 08:04 PM   #7
driven2exceSS
Thank you for doing the digging to find this info...
I came up with the same part numbers for the F/R assemblies, just didn't realize they were the same on all 6th gen Camaro's. Certainly was unaware that they are the SKF x-tracker hubs.
Old 06-07-2020, 10:10 PM   #8
TrackClub
TrackClub's Avatar
Great info thx for posting it! Cheers!
Old 06-08-2020, 09:04 AM   #9
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Has anyone changed the rear hubs? That looks like a huge PITA
Old 06-08-2020, 04:40 PM   #10
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
The replacement ones are still good - SKF's. As mentioned before, on pulling rear wheel bearings / hubs, you can do it either with the tilt the knuckle down method by removing the upper link bolts or just fish sockets in past the half-shaft once the splines are out of the hub.
RUQWIKR is offline   Reply With Quote
Old 06-08-2020, 09:42 PM   #11
s13remi
Drives: 2018 Camaro SS
I believe ceramic wheels bearings are always a great upgrade! Longer life, less rolling resistance and a decent bit lighter. The link is for drag racing but I know it popular in roadracing as well
http://www.performancebearing.com/dragracing.html
s13remi is offline   Reply With Quote
Old 06-08-2020, 09:43 PM   #12
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
it looks horrible but it isn't bad...remove the 36mm nut then the assorted suspension arms to swing the assembly away from the axle splines. Remove the 3 retaining bolts for the bearing assembly. I can do it in less than an hour start to finish.
Old 06-08-2020, 10:38 PM   #13
driven2exceSS
Cha-ching!! Good thing they're out of stock lol. Cough-cough
Old 09-26-2021, 05:44 PM   #14
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
I'm not sure how good the stock wheel hubs can be if they fit all Camaro's! There is a big difference between a ZL1 going around a track and a 4 cylinder being driven on the street...
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
