Old 06-06-2020, 03:20 PM   #1
plus1zero
Don't tread on me
plus1zero's Avatar
Drives: 23 Sierra X31, Past 2017 Fifty 2SS
Performance shift active message not popping up?
I got out and played a bit today but noticed going into sport mode when I sat still and floored it, the message wasn’t popping up. Still felt like it was doing its thing “popping” in between gears and didn’t feel any different, but would there be any reason I’m not seeing it now?
plus1zero is offline   Reply With Quote
Old 06-06-2020, 11:14 PM   #2
If you blip the throttle (to the floor and back), it should always display immediately. When you just floor it and hold it there, I've found that the message comes up much later, once you've eased up a bit.
Old 06-07-2020, 09:28 AM   #3
L8Apex
Drives: 2016 2SS
'Skip shift' only comes on in the lower gears at low speed and low rpm, like in your neighborhood. They sell a $10 part on ebay (.50 resistor) that defeats it, is undetectable and won't harm your warranty if they did. Maybe you have an automatic?
L8Apex is offline   Reply With Quote
Old 06-07-2020, 04:29 PM   #4
Nightfall ss1le
Nightfall ss1le's Avatar
Drives: 2020 A10 ZL1 1LE
He’s definitely talking about an automatic.
Nightfall ss1le is offline   Reply With Quote
Old 06-07-2020, 10:16 PM   #5
Yep. Blipping the throttle on the A8/A10 is the equivalent of downshifting immediately on a stick shift to the gear that corresponds to 3.5-4k rpm at the given speed, then trying to stay in this rev range during subsequent part throttle shifts.
This behavior is sustained until performance shift mode is turned off, which happens automatically a few seconds after easing off the throttle or flipping the shifter to manual mode and back to drive.
Old 06-08-2020, 12:29 PM   #6
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Maybe you need to be in Sport or Track mode for it to work?
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 06-08-2020, 12:31 PM   #7
RyanR623
Drives: SS A8, NPP, Red Hot
Huh, never knew this. Thanks for sharing. So just quickly press the pedal to the floor and let off?
RyanR623 is offline   Reply With Quote
Old 06-08-2020, 01:54 PM   #8
Spartan268
Spartan268's Avatar
Drives: HB 2SS
+1 must be in sport or track mode for it to kick in. Touring it will not appear
Spartan268 is offline   Reply With Quote
Old 06-08-2020, 01:59 PM   #9
Zr8000
Drives: Chevy Camaro
Yep. And as said below must be in sport or track mode. Chevy dude has a good video showing how it works on YouTube
Zr8000 is offline   Reply With Quote
Old 06-09-2020, 07:27 AM   #10
rspitler
rspitler's Avatar
Drives: 2017 SS Convertible
Do you have a link to Chevy Dudes video? He has a ton of videos on his channel and difficult to find the one your talking about
rspitler is offline   Reply With Quote
Old 06-09-2020, 09:21 PM   #11
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
i don't recall seeing the message from a stand still, but it will pop up if your driving and give the gas a quick kick and let off in sport mode.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 06-10-2020, 01:21 AM   #12
Zr8000
