Old 06-03-2020, 02:02 AM   #1
Clos.95
Clos.95's Avatar
Drives: Black 1SS
Can a Trans tune get rid of the A8 shudder?
Like the title says, has anyone had the A8 shudder then get a trans tune and adjust the line pressures and get rid of the shuddering?
Any info will help thanks
Clos.95 is offline   Reply With Quote
Old 06-03-2020, 09:05 AM   #2
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
I've read many of times that a proper trans tune can totally eliminate the shudder. This will be the first thing I do when my warranty is done
HCI2000SS is offline   Reply With Quote
Old 06-03-2020, 09:21 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Some have yes...some have also had it return. Just depends on a couple of variables. Is the converter damaged and/or was the new fluid used. I would suggest doing the latest fluid flush first then addressing the Tcc slip tables in the TCM.
Old 06-03-2020, 11:24 AM   #4
RyanR623
Drives: SS A8, NPP, Red Hot
Was going on 7k miles (19,000 on her now) on the new mobil one fluid fix and no shudder before my engine blew. Crap, now i'm wondering what fluid they put in when they changed the engine. Completely forgot to tell them to make sure they put the mobil back in. Hopefully they looked at the service records but i doubt it. I'll likely have to go back for the mobil again. FML
RyanR623 is offline   Reply With Quote
Old 06-03-2020, 03:40 PM   #5
aronSlusa
aronSlusa's Avatar
Drives: '16 2SS
Mine went away after what I think was zeroing out the tables when I had Tedd tune mine a few weeks back.
So nice, and he got rid of an annoying opening and closing of the TC that the previous tuners couldn't seem to get rid of.
aronSlusa is offline   Reply With Quote
Old 06-03-2020, 04:05 PM   #6
Bohanan23
Drives: 2016 Camaro 2SS A8
It's the trans fluid. Update the fluid and I'm willing to bet the shudder will go away. I definitely wouldn't be tuning currently if you're having trans shudder. Leave ECM/TCM untouched until you resolve it.
Bohanan23 is offline   Reply With Quote
Old 06-03-2020, 06:55 PM   #7
Clos.95
Clos.95's Avatar
Drives: Black 1SS
So weird, so about a month ago i did a major service done new diff and trans fluids, brake fluid, some injector cleaner bs, and after that the trans started shuddering and is just unbearable now. It’s the latest fluid too with the mobile 1 ATF. My car is currently at the dealership but I’m afraid they seem a little useless might try another dealer ship hopefully they take care of it.
Old 06-03-2020, 06:56 PM   #8
Clos.95
Clos.95's Avatar
Drives: Black 1SS
Do you happen to know what he did exactly so I can speak to my tuner, I heard zeroing out the slip tables completely helps or Atleast in 7-8 gear
Old 06-04-2020, 11:04 AM   #9
KingLT1
KingLT1's Avatar
Yes it helps...The slip tables are a part of the problem. You need to Zero out the TCC slip tables for all gears and turn off AFM/DOD. That being said at this point you might need a new torque converter if you have been driving it with the shudder.
Old 06-04-2020, 04:23 PM   #10
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
No, I had it tuned out the same time I did the triple flush a couple years back and it came back after 6k or so miles. I'm just getting a circle D. Done playing around with it
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
Old 06-04-2020, 05:04 PM   #11
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
You did it too late IMO. As King alluded to, you need to tune it before any damage is done. If you have any shudder, you’ve already begun the process of damaging the TC clutches. Since the tune cannot go back in time to prevent that, it’s likely going to come back. Your plan for a Circle D is a good move.
Old 06-04-2020, 05:34 PM   #12
Darth Martel
Darth Martel
I've only got 17k on my car. I did the triple flush around 10k after a month of experiencing the shudder. It took that long to show up, which was a couple years after I bought the car new. I only drive maybe 5k-6k a year. And once I noticed it come back at 16.5k, I just drop it into 7th when I get to cruising speed. The shudder only happens in 8th. I'm getting a cam anyhow so, figured I'd just take care of the torque converter at the same time. I'm just hoping my transmission doesn't experience any fu@&ery from GM's shitty torque converter. Time will tell.
Old 06-04-2020, 11:26 PM   #13
Brudda*Termite
Brudda*Termite's Avatar
Mine was the fluid. Service advisor told me the original stuff used on the 16-17 model years was hydrophilic and it was worse in high heat and humidity environments, which describes my area to a T!
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon
Brudda*Termite is offline   Reply With Quote
Old 06-05-2020, 12:41 AM   #14
KingLT1
KingLT1's Avatar
Tuning needs done right away. Also The triple flush from a couple years back isn't the same procedure being used today. As previously mentioned, the new fluid flush procedure should be done first. Good choice on converter!!
That being said I am at 11k miles and no shudder with tuning and original fluid. I still want to get the fluid flush and new fluid as a preventative at some point.
