![]() Drives: 2018 ZL1 Join Date: Apr 2017
Cold air intake recommendations
What’s some good cold air intakes you guys have either herd of or have installed in your SS?
#2 | |
2020 Shadow Gray 2SS
https://www.shopchevyparts.com/perfo...-92304337.html
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Rotofab is the one to go with.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#4 | |
TD
Drives: 2017 2SS, 2014 Mercedes C300 Join Date: Feb 2020
#7 |
#8 |
I don't but I'll try to get one next time I have the car out...
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
the factory air box is pretty good at getting cold air. i saw ambient iats when the car was stock. i put 2” stainless NON COATED headers on my car and cut the bottom half off of the stock air box. iats now hover 2-4* above ambient. car runs good, i can’t justify the money to pick up maybe 3-5 hp.
#10 |
TD
Yea. Its been in since i had about 1,000 miles on the car. Dry filter. The hood seals it. It's expensive but well worth the money IMO. Changed the tone of my exhaust, louder too. Also proven to add horsepower.
Here is a link on here from Rotofab. https://www.camaro6.com/forums/showthread.php?t=471120 |
#11 | |
#12 |
TD
Oiled filter is said to catch a little more debris than a dry filter. Oiled filter has to be maintained more. It has to be cleaned and re oiled. IMO there is no discernable difference between the dry and wet filters. A oiled filter needs more maintenance .When you re oil a wet filter you have to be careful to not put too much oil on it as it may ruin your mass air flow sensor. Dry filter you just use some compressed air, blow it off and re install it.
#13 |
![]() Drives: Black 1SS Join Date: Dec 2018
Rotofab Dry, if not that then a green drop in filter
#14 |
![]() Drives: 2017 Camaro 2SS 50th Anniversary Join Date: Sep 2017
Rotofab
| Tags |
| 2016 - 2018 ss, 6th gen, camaross, cold air intake |
