Old 06-02-2020, 12:52 PM   #1
JasonGofast
Used to own a ZL1
Drives: '16 Z06
Dash rattle found! Now how to fix?
For the past 300 miles I've had a rattle somewhere on my dash. A bit upset because the car doesn't even have 1k miles! Well I finally found where it was.
On the gauge cluster there is the silver surrounding with a black piece above, and below. When I squeeze the silver piece from above and below with my fingers on the black pieces the rattle stops. See image below.
https://imgur.com/kjxVZqZ
Now then how can I go about fixing it? Squeeze some glue under there? Get a foam piece and stuff it in there?
JasonGofast is offline   Reply With Quote
Old 06-02-2020, 01:21 PM   #2
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
see if you can find a dash disassembly diagram and depending on how it goes together tighten a few screws. but it its just regular push in clips maybe a few tooth picks pushed it. foam will probably need you to take the dash apart to do it correctly.
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 06-02-2020, 02:09 PM   #3
Mark R
Drives: 2018 ZL-1
Those silver pieces just pull out very easily. Pull them straight back towards yourself. Then you can at least have a look inside.
Old 06-02-2020, 02:16 PM   #4
Baldilocks01SS
Baldilocks01SS's Avatar
Drives: SEARCHING
GM really cheaped out on the dash material anyway....
Baldilocks01SS is offline   Reply With Quote
Old 06-02-2020, 05:38 PM   #5
Redlinez
Shifts under load
Redlinez's Avatar
On my 17, it was coming from behind the radio screen. You pop off the plastic trim panel on the bottom edge and it exposes two little like 7mm bolts. I removed those, tilted the screen down and applied some foam strip behind the edges. Rattle gone!
22 Suzuki GSX-S 1000GT blue
Old 06-03-2020, 10:33 AM   #6
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1(FEA suspension) Rapid Blue
Is stuff like this covered under warranty?
Crushed 1LE is offline   Reply With Quote
Old 06-03-2020, 02:15 PM   #7
19Nasty1le
Craig
19Nasty1le's Avatar
Drives: 2019 ZL1 1LE
I’d imagine not it’s just shit build quality.
19Nasty1le is offline   Reply With Quote
Old 06-03-2020, 02:33 PM   #8
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
yes. 3/36 bumper-bumper
Old 06-03-2020, 04:33 PM   #9
Coded4SS
Drives: 23 Zl1
if its broken clips or loose from the factory the dealer should replace. If its barely anything take it out, use some 3m felt tape anywhere the materials make contact to each other then put it back in. Itll be gone.
Coded4SS is offline   Reply With Quote
