Old 05-29-2020, 06:54 AM   #1
Sabrina2016
Drives: Chevy camaro
Tires
I apologize in advance if this question has been answered elsewhere but I cannot seem to find a direct answer.
2018 ZL1 with worn out stock tires 285/30/20 front and 305/30/20 rear. I would like to go with Michelin ps4s but the fronts are out of stock but 295’s are available.
If I go up one size front and rear to 295’s and 315’s will I have any clearance issues and even more importantly will it turn on a check engine light due to the computers not liking the different revolutions?
Thanks
Sabrina2016 is offline   Reply With Quote
Old 05-29-2020, 08:22 AM   #2
Fredtp
Fredtp's Avatar
Drives: 2019 ZL1 A10 Black Mosaic
Thanks
I am running MPS4s 295/30/20 and 315/30/20, no clearance issues at all.
2019 Black Mosaic ZL1 A10
Kong Ported SC, 2.3 Grip Tec, Roto-Fab Big Gulp, NW103 TB, Mighty Mouse CC, ADM Expansion Tank, ARH 1 7/8 Headers, Catless 3" X-Pipe, Corsa Extreme, Eibach Springs, BMR Cradle Lockout, BMR Trailing/Control arms.
Fredtp is offline   Reply With Quote
Old 05-29-2020, 12:21 PM   #3
Sabrina2016
Tires
Thank you Fredtp,
I see you are listing yours as being heavily modified so I would assume that you have different software for the engine computer. If there are no issues with the different revolutions I would prefer to go one size up with the tires.
Thanks
Old 05-29-2020, 03:10 PM   #4
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Sabrina2016, have you checked on Tire Rack’s website for those stock sizes? They may have some in stock and you can order directly from them. They may have an installer in your part of New York.
Old 05-29-2020, 04:12 PM   #5
Flowtie1
Drives: 2017 ZL1
No difference in revolutions. The 295 is wider not taller
Flowtie1 is offline   Reply With Quote
Old 05-29-2020, 06:46 PM   #6
Fredtp
Fredtp's Avatar
Thank you Fredtp,
Thanks
My car is lowered also and no issues. And speedometer is same.
Old 05-29-2020, 07:14 PM   #7
Sabrina2016
Tires
Thank you to everyone for the responses. I have been checking tire rack for about a week and the stock size for the front is special order without an expected delivery date so I think I will go with the one size up front and back.
Old 05-29-2020, 09:12 PM   #8
KSA464
Drives: 2018 2SS
maybe post this in the tire and wheels section? I dont know...
KSA464 is offline   Reply With Quote
Old 05-29-2020, 11:33 PM   #9
ZL1naples
Drives: 2019 ZL1
I run 285s in front and 315s in rear. No light issues, no clearance issues, and no handling issues.
ZL1naples is offline   Reply With Quote
Old 05-30-2020, 12:56 AM   #10
JeffFox
Drives: 2018 2SS Coupe A8
I beg to differ.
295-285=10mm wider. 10mm x 0.3(this is the aspect RATIO)=3mm higher side wall x 2(top and bottom sidewall height combined) means the outside radius of tire is 6mm higher.
Respectfully submitted,
Jeff
JeffFox is offline   Reply With Quote
Old 05-30-2020, 01:16 AM   #11
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
I have the 295s up front (same wheel size and suspension as ZL1), no issues. My tire calc spreadsheet says the 295 is about 3mm (2.7-something) bigger in radius. It's nothing. 13.37 vs 13.48".
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 05-30-2020, 06:49 AM   #12
VinnAY
Drives: 18 1SS/1LE
Jeff
I was about to type this same reply
Old 05-30-2020, 08:04 AM   #13
Fredtp
Fredtp's Avatar
Thumbs up
You will not be disappointed
Old 05-30-2020, 09:35 AM   #14
JeffFox
Thanks Vinnay. Self correction
The Diameter (not radius) is 6mm larger so the tire is 6mm higher.
Jeff
