Old 05-28-2020, 12:28 PM   #1
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Extra fan for A10 radiator?
Just a question
I was thinking about adding an extra fan for the A10 overheat issue we are experiencing sometimes on a track.
In the front , horizontally, above the trans radiator with a manual switch.
That will provide an extra flow when we are just behind a car with no flow causing that overheat issue....
Anybody with this system already?
Biscuit.fr is offline   Reply With Quote
Old 05-28-2020, 12:34 PM   #2
URBAN LEGEND
URBAN LEGEND's Avatar
I haven’t heard of any overheating issues with the A10. I haven’t heard of anyone putting a fan on the tranny cooler either. Could it be something else causing the overheating?
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 05-28-2020, 12:38 PM   #3
cirpower
Drives: Camaro ZL1
Originally Posted by Biscuit.fr View Post
Just a question
Which fluid is overheating? The transmission fluid? How hot does it get?
cirpower is offline   Reply With Quote
Old 05-28-2020, 01:31 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I wouldn't worry about it. I've been in ambients over a hundred on track and never had any cooling issues. Fans don't do much if anything over 40 miles per hour.
Old 05-28-2020, 04:24 PM   #5
Biscuit.fr
May be the issue is solved.
Very first ZL1 had hot trans fluid on track when following other cars reducing the flow coming trough the radiator.
Rising slightly above 200 I think.
Haven’t heard for a while.
Few issues in 2018.
No issues if you are pushing Hard alone
But following super close for couple of minutes, should rise and overheat (trans fluid)
Old 05-28-2020, 05:35 PM   #6
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Correct me if I’m wrong but, I think the normal operating temp for the trans is ~203.
OP, think the issue with some folks experiencing overheating was due to sitting behind other cars for too long. FTR, I have no idea what “too long” constitutes but, so long as your letting the front get some good clean air once in awhile it’ll be fine.
