Old 05-28-2020, 08:57 AM   #1
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
OEM cam specs
Anyone have the cam specs for the stock 6th Gen LT4 cam?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 05-28-2020, 09:41 AM   #2
DemonZL1
199
DemonZL1's Avatar
Drives: like a granny
LT4 Cam Specs
Part Number 12642245
Duration @ .050 in. (int./exh.) 189°/223°
Valve Lift (int./exh.) 0.492 in./0.551 in.
Lobe Separation Angle 120°
Cam Gear Attachment 1-Bolt
Cam Gear Poles 4X
Active Fuel Management (AFM) Yes**
Variable Valve Timing (VVT) Yes
NOTE: **All versions used AFM with one exception — the Chevy Camaro ZL1 with manual transmission.
https://www.onallcylinders.com/2018/...ads-cam-specs/
2024 Silverado ZR2 LZ0 Duramax
2021 Shock SS 1LE A10
www.youtube.com/@demonworksmotorsports
Anderson composites coupon code : Demon
DemonZL1 is offline   Reply With Quote
Old 05-28-2020, 01:33 PM   #3
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
[QUOTE=CarbonZLE;10799258]LT4 Cam Specs
Cam Gear Poles 4X
Thanks. Very mild cam. I guess because of the forced induction?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 05-28-2020, 04:05 PM   #4
crosive
Drives: 18 zl1
no zl1's use afm, although the hardware is there
crosive is offline   Reply With Quote
Old 09-01-2025, 10:27 PM   #5
MilwPaul
Drives: 2023 Camaro ZL1
"Very mild cam. I guess because of the forced induction?"
Don't forget that the ZL1 has a cam phaser / VVT to move the cam around which makes it act like a bigger cam.
MilwPaul is offline   Reply With Quote
