Old 05-27-2020, 10:51 AM   #1
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
DeX cool pink part number
Hello, I have a 2017 camaro ss with pink coolant. What is the ac delco brand dex cool part number? Thanks in advance.
Magnum922 is offline   Reply With Quote
Old 05-27-2020, 11:35 AM   #2
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Or pre-mix
https://smile.amazon.com/gp/product/...KIKX0DER&psc=1
I`m Batman is offline   Reply With Quote
Old 05-27-2020, 11:45 AM   #3
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
I haven't seen pink DexCool for sale in North America, only the orange type posted above.
I doubt they are chemically different, just with different dyes. I used 150 mL of DexCool with 150 mL of boiled+filtered water to top off the lower coolant reservoir.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 05-27-2020, 12:24 PM   #4
Magnum922
Magnum922's Avatar
I wanted to try to keep it the pink color.
Old 05-27-2020, 12:44 PM   #5
VQ35DE
Drives: 2013 / 2SS / RS / L99
When did DexCool go pink ? Thought it was still orange.
VQ35DE is offline   Reply With Quote
Old 05-27-2020, 12:57 PM   #6
UnknownJinX
You probably need a little more than half a quart/litre. Personally I wouldn't worry about it, the change of hue will be very slight since there are 10+ quarts/litres of coolant in the whole system.
Some also say online that the orange dye will eventually break down after heat cycling and become pink. I doubt this is true but at the same time, you could probably have a pot, put some mixed DexCool in it, boil it, cool it, rinse and repeat a few times to find out.
Factory fill is pink, as the photo above shows.
Current:
Past:
Old 05-27-2020, 07:06 PM   #7
cmfhsu
Drives: 2019 2SS 1LE
Dex cool turns pink when you mix it with distilled water. Pink factory Dex Cool is the same exact thing as orange dex cool concentrate.
I bought premix for my camaro because I didn't want to bother using a second container to mix. It came out the exact same pinkish color as in the reservoir and was roughly twice as expensive.
cmfhsu is offline   Reply With Quote
Old 10-20-2020, 12:52 AM   #8
D_H
D_H's Avatar
Drives: '19 Camaro M1SS1LE
Does this car LT1 use coolant? Should it be normal to have to add coolant every few thousand miles? I've seen a few more LT1s on YouTube and on here, that also seem to be low.
I thought it was a closed system; the manual says the lower tank level can evaporate over time or in hotter climates. I thought coolant wasn't supposed to do that.
D_H is offline   Reply With Quote
Old 10-20-2020, 01:41 AM   #9
UnknownJinX
No seal is perfect, so you always have some evaporation happen.
And it's not just Chevy's. My RX-8 would see a small amount of coolant loss, even with a new cap. As long as it's not excessive, I wouldn't worry about it.
That said, there are a few examples of empty lower reservoirs I see on the web and one case in real life. I checked out a friend's Camaro V6 and saw that the lower tank was bone dry while the top is missing some coolant. I gave him some of my Dexcool, mixed it with distilled water, and topped it off. I don't know how it is now, but I think it should be okay.
Current:
Past:
Old 10-20-2020, 07:35 AM   #10
Invertalon
Drives: 2021 2SS
I don't think that is low? Mine brand new from the factory looks just like that photo, level wise. Thought it was low until I checked the manual.
Here is the "full" levels as shown in the manual... The bottom tank appears to be properly filled. By design, it should look 'low'. The top one should be filled to the brim.
Invertalon is offline   Reply With Quote
Old 10-20-2020, 02:30 PM   #11
UnknownJinX
There are some reports of the lower tank being completely dry with top tank missing some coolant on the forum.
https://www.camaro6.com/forums/showthread.php?t=555908
Sent from toaster or something
Current:
Past:
Old 10-21-2020, 08:18 PM   #12
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
I just followed those links and both said this does not fit your 2017 Camaro SS. I know Amazon gets things wrong sometimes though.
craigss50 is offline   Reply With Quote
Old 10-25-2020, 10:06 PM   #13
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
amazon price gouge $13 at my dealer
Old 10-25-2020, 10:35 PM   #14
Quester
Quester's Avatar
Drives: 16 2SS Convertable
You can use Water Wetter, same color, also helps reduced engine heat.
2SS Convertible A8, NPP, GMPP CAI, Flow tie grill, Mishimoto Oil catch can, Eibach lowering springs.
Quester is offline   Reply With Quote
