Old 05-26-2020, 11:13 AM   #1
ud03803
ud03803's Avatar
Drives: 2018 Camaro 1SS Blue
Looking for fuel line ideas...
As you can see in what I circled in the picture, I would like to replace these fuel lines with lines that look more "racy" or "classical hot rod". I am thinking like the blue/red AN fittings - anything but black! These engine bays have so much black in them everything is lost and just doesn't look very good. Does anyone know a good place to buy these? Is there a kit somewhere? These press on quick connect fittings - what would they be described as so I can get the right parts? I have seen 3/8" quick connect fittings, are those it? Any help is appreciated! Thanks
CNC Ported 12:1 Heads/Kooks 1 7/8"/Hellion custom cam/Atomic MSD/Tony Mamo V2 PTB/K&N CAI/E85/All LT4 Fueling/Mystery Axle-back/Gap Juice
ud03803 is offline   Reply With Quote
Old 05-26-2020, 10:47 PM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
You'll need to build a custom AN line. You can cap off the solid lines with quick disconnect 3/8" line/an fitting. You can plug an an line right into that.
Juiced1 is offline   Reply With Quote
Old 05-28-2020, 10:57 AM   #3
ud03803
ud03803's Avatar
Thanks!
Old 06-07-2020, 03:36 PM   #4
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I just installed Chevy's strut tower brace and zip tied the fuel line behind it. Can't see it at all and I always wanted an excuse to get a brace. It'll be compatible with your Masimo catch can too.
https://www.thatgmpartsguy.com/oem-p...YtMmwtdjgtZ2Fz
Ventmaster is offline   Reply With Quote
