![]() Drives: 2019 Camaro 2SS Join Date: Apr 2020
Procharged oil leak need help.
As title says. I threw a Procharger and been using a the Procharger canned tune for a month now. Last night when I did a pull a shit ton of white smoke came out the back. Pulled over and open good, oil was everywhere. Turn car back on looking for leak, could not find it. Started driving away and wasn’t losing oil, everything was good. Drove all the way home from Connecticut. Next day went and got oil, filled up. Did a quick 2 second pull, nothing. Car runs and drives fine. Did a prolonged pull of about 5 seconds and got into 4th gear, it started it again, hence the piks right now. Any info guys? Just base Procharger tune and 2 step spark plugs.
Please call/text 9788095636, thank you.
![]() Drives: 18 2SS 1LE, 20 Canyon Denali Join Date: Feb 2016
I’d bet on the front seal, pretty common when you go FI. Often times though it comes with orther damage potential ... you can start with the seal replacement on the crank and hope or have a reputable shop take look. I’m sure others with a lot of experience on the topic will chime in.
Mike
Current Garage: 18' 2SS 1LE, Hyper Blue 23' GMC Canyon Denali Previously: 20' GMC Canyon Denali 16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss) 14' Ford Edge Sport 06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
I've heard the same about the front seal with FI. If I'm not mistaken ls3 front seals fit and are better.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
![]() Drives: 2017 2SS, M6, Silver Join Date: Jun 2018
thats defintely a front crank seal. the LT1 front seal is super thin and doesnt like boost. the LS3 front crank seal is the better replacement. with that said you may have to go through and also add a vented breather for the crank case or a vented catch can. you generated enough pressure in there to blow the front seal out, the LS3 seal will hold the front down trapping that pressure and may blow something else out or generate more blow by.
17 2SS, Pray Performance Forged/Stroked 416, 2.9 Whipple (Pray ported), Stage 2.5 Pray ported heads, RotoFab Big Gulp, Katech 103mm TB, Pray Performance stage 3 forced induction cam, 8.855” crank shaft lower pulley, 3.00 S/C pulley, LT4 Fueling, SMG auxiliary fuel system, 2' TSP LT headers with X-Pipe, Magnaflow Competition axleback, Mighty Mouse Wild catch can, Hurst Short Shifter. Tuned by Pray Performance. 1011WHP/982WTQ
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
https://www.camaro6.com/forums/showthread.php?t=550461
Happened to me I now run the Metco breather after a rebuild. |
#8 |
![]() ![]() ![]() ![]() Drives: CAMARO Join Date: Jan 2017
What is the average cost to build bottom end? Nothing crazy .. just for a shits n giggles ..
#9 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
