Old 05-24-2020, 07:51 AM   #1
Aaron07
Aaron07's Avatar
Drives: 2017 2SS F1FTY
Codes p2535 & p069e
I just bought a 2017 2SS bone stock with 16k miles and two days later I had the CEL light come on in with these two codes.. P2535- ignition switch run start circuit position high. P069e- fuel pump control module requested. I took it to the dealer and after some diagnostics he found the battery would not pass the test and also my key fob battery was dying. So battery failure in car and key fob. They work together and are important to keep a good voltage. Voltage problems can cause all sorts of weird things to happen. I replaced both batteries and all has been good now for a few days. I wanted to share in hopes this can help someone else with similar issues.
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
Aaron07 is offline   Reply With Quote
Old 05-24-2020, 08:38 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Congrats on the car. Hard to beat a ‘17 2SS, am I right?
There are so many different electronic modules in these cars, solid power is a priority. The OEM batteries don’t seem to be lasting too long unfortunately. Glad it was an easy fix though.
Old 05-24-2020, 09:02 AM   #3
Aaron07
Aaron07's Avatar
Thanks! Yeah it’s an awesome car. I had 2010 2SS, huge difference tech wise. Gorgeous car indeed
