Old 05-22-2020, 12:09 PM   #1
Chris 2018 ZL1 A10
Drives: Chevy Camaro ZL1
Wheel studs: Metal protection needed?
Hi Guys,
After I finish washing my car, I use my electric blower to remove water off the wheels, especially the lug nuts out of concern for rust/corrosion. I understand that putting any oil/grease will protect the metal but will also skew the torque value and potentially cause over-tightening of the lug nuts.
Thoughts, suggestions?
Thanks,
Chris
Chris 2018 ZL1 A10 is offline   Reply With Quote
Old 05-22-2020, 01:21 PM   #2
Markoz28
Drives: 18 ZL1 nightfall grey A10
I have not seen any rust on my wheel studs. I would not add any oil or grease to them.
Markoz28 is offline   Reply With Quote
Old 05-22-2020, 01:24 PM   #3
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Originally Posted by Chris 2018 ZL1 A10 View Post
Hi Guys,
Thanks,
Chris
I think you should be good, using the blower as you described.
CW3SF is offline   Reply With Quote
Old 05-22-2020, 01:26 PM   #4
SpeedLimit
Drives: 2019 F150
Dont use the tuner open end lug nuts and you won't need to worry about rust on the wheel studs.
SpeedLimit is offline   Reply With Quote
Old 05-22-2020, 02:07 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
no worries...if that were a worry, how could anyone drive in the rain and not risk lugnut rust issues?
Old 05-22-2020, 08:27 PM   #6
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1 1LE
Get yourself a set of black security lugs. Problem solved. No rust and secure as Fort Knox!
Crushed 1LE is offline   Reply With Quote
Old 05-22-2020, 09:37 PM   #7
Chris 2018 ZL1 A10
Thanks fellas,
Chris
Old 05-27-2020, 08:16 PM   #8
Apexslayer
Drives: Zl1 1le
DO NOT put grease/oil on the studs!!!!
Apexslayer is offline   Reply With Quote
