![]() Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
ARP balancer crank bolt
I am getting ready to intall a new lower pulley and ATI balancer. There is two bolts that are referenced for the swap. 234-2503 and 234-2504. Which is the correct one I did read somewhere else that the 234-2504 was too long but it was the recommended one?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
2504 is for the LS7 which is dry sump and has a longer crank snout. Use the shorter one.
![]() Drives: 2018 Camaro ZL1 Join Date: Feb 2011
Here ya go!!
![]() Sent from my SM-G960U using Tapatalk
AudioControl 2x LC6.1200, LC1.1500, Audison Bit One Virtuoso, Bit Play HD, Frogs, NavTV M650, JLA 12W6
Why are some people saying that the longer 234-2504 ARP bolt is the one?
Dyno Show Queen LOL
Just use the ATI bolt.. people screw up here all the time its supposed to be a LS bolt for correct length and most importantly correct flang size to seal and not to crush drawing damper on.. here some useful stuff...
ATI 918856 Damper ATI 916227 or Lingenfelter L220170709 9.17 pulley GATES Greenback k080845HD for 9.17 ring LS1 ATI 951499 damper bolt summit NGK 6510 1 step cooler plugs
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
I recently used ARP 234-2503 bolt. No issues. A comparison:
![]() Note this was on an LT1 with LT4 balancer, but believe they are same.
#7 |
some LT4s are dry sump (Z06) and likely require the longer bolt like the LS7
#8 |
![]() Drives: 18 ZL1 mostly stock Join Date: Jan 2020
I used the ARP 2503 when I put mine back together. If you use this bolt make sure to put some sealant on the face of the washer that goes into the balancer. if you don't you will have a good chance of an oil leak sooner or later, the factory bolts come with sealant already applied and the ARP does not.
07 LMB Z06 Cartek 4x heads and cam, ARH, Vararam, FAST 102, NW 102
18 ZL1 M6 MTI cam, FED heads, FBO's |
#9 |
![]() ![]() Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85 Join Date: Oct 2016
Hey guys is the 234-2503 the only bolt we need?
Well............ At least you tried. lol
