![]() Drives: 2018 camaro ss 1le Join Date: Feb 2019
Muffler delete
I was wondering if theres a way to do a muffler delete while keeping the npp so i can still use stealth mode
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Read that to yourself again, but slower.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#3 | |
![]() Drives: 2016 SS Join Date: Oct 2019
![]() ![]() I'm going to HOPE that he just worded it wrong. ..One of those "I knew what I meant" moments!!! |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Well there is a way but maybe not the setup you want but I did it to my 2016 2SS.
Delete the suitcase muffler. Add a y pipe just after crush pipes, then do two pipes out of the y pipe. Inside pipe with a muffler and out side pipe straight piped with the NPP values still operational. It worked good for me, louder then stock that’s for sure but it made my next door neighbour happy because it was not a full muffler delete straight pipe till I got a cam.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
hmm.. Delete a muffler that has valves in it to control loudness... Deleting muffler.. which deletes the valves..
You could also get a stock NON NPP muffler and install it straight up like factory. THEN....cut the valve portion on the stock NPP suitcase. Splice some cut-out "Y" pipes somewhere downstream of the cats and put the NPP valves in the cutouts. Extend the wiring pigtail to reach, boom.....there ya go.
#7 | |
Bubmobile
Drives: 2018 Camaro ZL1, 2014 Corvette Z51 Join Date: Oct 2020
If you want stealth + loud, put cutouts before your suitcase. Open it for free flow, close to push thru stock exhaust. I have QTP cutouts. Sound and video of opening here:
#8 |
![]() ![]() ![]() ![]() Drives: 23 ZL1 6speed Join Date: Aug 2020
The valves are technically not in the muffler, but they would have to be reinstalled if doing a typical muffler delete. It wouldn't make much sense to do what the OP has posted..
My first thought was doing cutouts as well, as bubs suggested. I have thought about doing those for mine but I'm not sure how it will sound haha. |
#9 |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
I'd tend to agree with the cutouts idea. Similarly, you could do a little bit of fab and have the outer tips connect to the exhaust in front of the muffler using y-pipes. Basically cutouts but using the original valve locations and tips instead of aftermarket valves and/or exhaust dump locations. You'd need to keep the OE muffler to keep stealth mode. All stealth mode does is keep the valves closed all the time and force all exhaust flow through the full suitcase muffler. Deleting the muffler also delete's stealth mode lol.
2017 SS 1LE.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
optional cutouts like this are still illegal in california and if you ever do get caught by a cop and told to see a ref, they will test exhaust in both modes and would be able to tell you have a cutout if you try and hide the switch if you rewire the valves for manual trigger. Our cars are already fairly loud, pretty much any aftermarket exhaust puts us over the legal limit technically. I wouldn't be surprised if even the stock exhaust goes over the limit. But santa ana is probably less anal than newport and such places.
NPP branches into two pipes prior to the muffler, one is a pass thru (the loud one) the other is baffled. If you want a muffler delete for your "loud side", just cut the pipe that corresponds to the pass-thru section. Cap it on the muffler side and retain the stock muffler. Should be a very simple job with a exhaust pipe cutter. |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
So you remove the muffler but want the NPP for stealth.
WOW. |
#12 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
#13 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Drunk posting this early Night?
Give me a few hours, I got some catching up to do. |
#14 | |
My bad. |
