Old 05-19-2020, 04:36 AM   #1
Jbanta1983
Drives: 2019 2ss 1LE
Does this look normal??
Check out my wideband jumping around..my camera is isnt good enough to pick up the digital but you can still see it moving. This is a 3rd gear pull
https://youtu.be/QXB8sCNoCfo
Jbanta1983 is offline   Reply With Quote
Old 05-19-2020, 10:30 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The wide fluctuation is likely because the MAF isn't dialed in. It really shouldn't fluctuate much more then 1/4 of a point if the tune is spot on. You should see it moving between 11.9-12.1.
Old 05-19-2020, 10:33 AM   #3
Jbanta1983
I spoke with Ted Jannity he was saying it looks like an electrical problem, he told me to check my ground. What's your thoughts on that?
Old 05-19-2020, 10:34 AM   #4
Jbanta1983
Also this is a procharger tune so I doubt its spot on.
Old 05-19-2020, 11:13 AM   #5
KingLT1
KingLT1's Avatar
That could be, but if it was a ground I would think it would be blanking out or jumping up to like 24 or a max number simulating that it's not getting a reading.
