![]() Drives: Camaro ZL1 Join Date: May 2020
Performance Reduced. Reduce clutch usage. Error message.
Keep on getting error message when accelerating fast in 4th and 5th gear. Car cuts acceleration even when pressing the gas pedal. If I release it then press pedal everything goes back to normal. Happens very often when flooring car. Have not tried to replicate in lower gears. Happens with and without rev match on. Read in manual that error code comes up when car notices clutch slipping. But clutch seems fine to me. Didn’t notice any issues. 2019 manual ZL1. 8k miles.
Any suggestions? |
***Update***
Has been getting worse over time. Dropped car of the the local Chevy dealership. Awaiting results, they told me could take 3 to 4 days just to diagnose. Seems ridiculous. |
Good luck - problems like this are so frustrating! Just curious - are you at a low rpm in fourth or fifth when you floor it? I don't ever floor mine in fourth or fifth when cruising. I down shift to third and then by the time I wind out 3rd for the shift I am way over the speed limit and let out of it in 4th. I can see the dealership balking a little at letting a tech try to duplicate the problem since it could involve some pretty high speeds to check out 4th and 5th gears.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
You're sure your left foot is 100% off the clutch right?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#6 | |
I recently just got a text from the dealership saying they replicated the issue, and will keep me posted. They close in the next 30 minutes so doubt ill hear anything today. Hopefully tomorrow. |
#7 | |
I wish you the best and keep us posted on the findings.
#8 |
Update
Received another message from Service Advisor. Stated that they confirmed on test drive that the clutch is indeed slipping. There is no stored data so they will have to do a tear down to find the failure. Told me that he will give me the next update tomorrow afternoon. On another note, I do not understand what they do with the vehicle in the mean time, just have it sit while they work on other cars? If they are working on a car and no parts are needed why not just stick with that car until they have a diagnosis and not put it off till the next day. Im guessing it has to do with profit or some quota to get to other cars first. |
#9 |
***Well Just got a big update****
Service Advisor gave me a call. They found out what the issue was. A little backstory, I just recently purchased the car. About 3 weeks ago. They found out that the car has undergone 10 ECM changes, and that the pully system for the supercharger has been changed to something stronger, not a mechanic or technical person with cars, so dont know much about this topic. Long story short, they say that the current clutch cannot handle the power output and is slipping, and probably is worn. To make matters worse the factory warranty is void. The drive train warranty is also void. They said they do not have the equipment to fix the situation. So..... Guess I am ****ed. Hope there isn't any sensitive language folks in here. I gave the dealership that sold me the car a call. Buick dealership, mid sized. I talked to the salesman that sold me the car, he was just as surprised as I was. He said that he will have his manager give me a call shortly. Will see how that conversation goes. He called back as I was writing this, told me I can take the car in and they will look at the clutch, but shits 3.5 hours from me. And no grantee they will fix anything. Called a local tuning shop. They said they will take a look at the car on Monday. So I set an appointment with them. I guess time will tell. Im thinking there are 2 options here, replace the clutch with something aftermarket strong enough to handle the extra output, or have them tune the car to lower output ( If that is a thing). And check the tune that is on there currently. No idea how much this will cost me. If anyone has any idea please let me know. |
#10 |
![]() Drives: 2016 Camaro 2SS M6 Join Date: Mar 2019
If it were me, I'd just put a better clutch in it at this point
#11 |
#12 |
***Update***
Took the car in to a local performance shop. Clutch is completely ****ed based on what the mechanic said. Looks like I have to replace it. He recommended a McLeoad Twin disc clutch, cost about $2.5k. Not familiar with any after market parts as I just bought my first performance car. Anyways labor is about $900.00. He said clutch should last me lifetime of the car. |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Niteb- Why did you purchase a MODIFIED ZL1 and not understand what you were getting into...
Was it bought from a dealer, private party etc.? They should have told you. Also a SLIPPING clutch is VERY APPARENT... you might be in a car you can't handle.... A Twin Disc Mcleod is about the best out there and very pricey.... as you found out... About 4 months ago we had a poster who didnot understand that leaving an automatic in AUTO was the best way to drive it...Lack of knowledge... We will try and help you, but need full info... who modified the car?
2012 Yukon XL Denali w/ 6.2 AWD Last edited by avalonandl; 05-26-2020 at 03:46 PM. |
#14 | |
I have not driven a manual car in about 8 years prior to this purchase. So I was a bit rusty first couple of days. Not sure if its possible to burn through a clutch that quickly. Not saying that I grinded it or what not. The slipping of the clutch and error messages did not come up until about week 2 after purchase. It only became apparent on week 3 when it gradually became worse. Did not show higher rpms and such until a few days ago. Prior to that kind of hard to tell with a new car and not driving stick for 8 or so years, at least for me. Not sure what you are insinuating that I may not be able to handle the car. Just because I am not familiar with it yet and was a bit rusty with my shifting does not mean I am incapable of learning and getting there. I joined this forum to gain knowledge. Who modified it I have no idea. Probably the previous owner. Carfax on the car indicate only one prior owner. Then the dealership getting it. Had no reports of any modifications. |
