Old 05-16-2020, 04:03 PM   #1
New_image
Drives: 2019 Camaro 1LE
Low torque whats goin on
First run was 1 7/8 no cats full exhaust, flowmaster cai. MM Wild 434hp 435tq.
The second ECS kit, snow meth (washer fluid), dsx breakout w/ mods above. 572hp 490 tq. Difference +138hp +55tq.
Dyno issues: The guy was using my afr gauge to tune. The print out only showed like 5 point something psi max and the boost wasnt even showing up till after 4k. (3 psi @ 4500).
One of the charge pipes on the kit had to be reduced (3" to 2 3/4) in order to fit around the headlight (2019). Im doing mods in sequence. Fuel is next on the shelf but what is going on with the torque is the first thing i want to know or is it normal to get 55 lb increase in torque with a centri.
New_image is offline   Reply With Quote
Old 05-17-2020, 08:05 AM   #2
RageWorx
RageWorx's Avatar
Drives: 2016 1SS A8 Camaro with MRC and NPP
My SS was the ECS test car for this kit (My car/dyno on the ECS website).
I went from 390hp/390tq (bone stock car) to 550hp/510tq on their dyno with the only mod being the ECS supercharger kit at ~7.5 psi WOT (I have a boost readout from the dyno run I'll dig that up).
So roughly +160 hp/+120 tq gains with no other mods.
Since then I've added ARH headers/mids + AEM watermeth and gained around 30 ft/lbs or more (and over 50 hp) at less boost (boost dropped to 5.5 psi after ARH system) and I haven't even pullied back to 7.5 psi yet (coming soon).
So it's hard to say but your torque does seem a bit on the low side (and my torque curve is a bit flatter than yours) but Definately don't expect Maggie or Whipple like torque levels with the Centri setup different ball games lol
What's your max ign timing/curve + vvt tuning look like ?
-Jon
2016 HB Camaro 1SS A8 with MRC and NPP 398rwhp/389tq stock #s(11.84 @ 117 DR only, ECS boost 550rwhp/510tq (dynapack #s) , same boost + AEM water/meth + ARH Headers/mids 600 rwhp+ (dynojet #s) TTP)10.8 @ 129.
2020 Ford Explorer
2003 SVT Cobra Coupe (just your average KB Terminator Cobra).
2013 Focus ST (e30 Tuned).
2004 Dodge 3500 Cummins Dually 6 spd manual (tow rig).
1997 Jeep Cherokee (Lifted and Locked XJ off-road rig).
RageWorx is offline   Reply With Quote
Old 05-17-2020, 10:04 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
My guess is the timing is low in the mid range and/or the VVT is untouched.
Old 05-17-2020, 07:43 PM   #4
New_image
Had a friend tell me the same thing.
Old 05-29-2020, 12:26 AM   #5
New_image
Found out the wrong pulley came with kit. I still need to check the timing like people were saying. I do have the tunes (stock, header, superchared) if anyone wants to check em out for me.
Old 05-29-2020, 07:15 AM   #6
wnta1ss
Drives: 2017 Camaro 1SS
What pullies did you get? My kit (used to have the ECS/Paxton) was ordered for a stock engine, and it came with a 32t on the supercharger and a 30t on the jackshaft, talking about the cog part of the system here. From what others who've purchased this kit have said, that is normal.
As RageWorx mentioned, having long-tube headers gives a lower 'boost' reading, which is because of the lower restriction. However, don't mistake this effect for actually losing anything, as the supercharger is still spinning just as fast. For a crankshaft-driven supercharger, blower rpm is what determines how hard you are pushing it, not so much the boost number itself.
Old 05-29-2020, 12:58 PM   #7
New_image
Hmm I did get the 32/30 combo. Talking with ECS they said i should have had a 34t jackshaft. We'll see what happens I guess.
Old 05-30-2020, 08:11 AM   #8
wnta1ss
I would say that your pullies are absolutely fine, and definitely not the cause of the lower-than-expected torque.
More comments about the torque, when I first had my ECS kit, it was weak for some unknown reason, one of the dyno sheets was 481hp and 471 torque. On the very same dyno, my bone stock car had read 395hp and 397 torque for reference. This was the base ECS kit with no methanol injection, and a completely stock exhaust system. So even not working very well, it still had gained about 74 lb/ft of torque with the base supercharger. Later, I tried the kit again, this time adding a DSX baro breakout. My guess, from how much faster it was that time, is that the torque gain from the base supercharger might have been 100 lb/ft or more, like RageWorx had experienced. No dyno runs in try 2.0, but actual performance told the tale, it ran some 10.9s in summer heat at the 1/4 mile dragstrip.
Old 05-30-2020, 09:48 AM   #9
New_image
Its a little frustrating because I have the lt4 stuff to put on and the way these gains are lookin I'll be lucky to crack a 100 ft lbs of torque, total.
