Old 05-15-2020, 04:09 PM   #1
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
Should I weld this together?
So attached is a photo of the point where the GM catalytic pipes are clamped to my aftermarket cat back exhaust.
I understand normal water condensation in exhaust....but it appears to be leaking at the clamp. Same issue last year, I had it cleaned up and re-tightened but now same problem again. ....Why is this happening? Will this rot through?
Exhaust is stainless, but it is also magnetic, so there must be some iron content that will rust...right?
I can hear the exhaust leaking sound until the pipes warm/expand to seal it. So I want to ask the shop to just weld the whole area together.
Is this a good idea or bad idea?
2016 SS M6
MR-02 is offline   Reply With Quote
Old 05-15-2020, 04:35 PM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Swap the clamps with preformed band clamps and use Permatex ultra copper on the slip connection prior to installing the band clamps.
Old 05-15-2020, 05:42 PM   #3
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
Hey thanks KingLT1, .....Last year, I asked about band clamps, they said the pipe starts curving too soon, and the band clamp is too wide, is that bs?
...But what are you thought on the welding idea?
2016 SS M6
Old 05-15-2020, 06:14 PM   #4
s346k
s346k's Avatar
Drives: like an old lady
you’ll have to remove almost the entire exhaust system to weld that connection. yes a weld is better but it’s gonna be a real pita.
Old 05-17-2020, 12:27 AM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
these https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Old 05-17-2020, 08:19 AM   #6
95 imp
Dumb Ass Deluxe
I would rather have the condensation leak out a "weep hole" than puddle in the pipe until it is hot enough to be vaporized again.
Old 05-17-2020, 10:29 AM   #7
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
Thanks JCunningham, ....I'll look into that
2016 SS M6
Old 05-17-2020, 06:47 PM   #8
BDPhoto519
BDPhoto519's Avatar
Are those pipes 2.75", I was under the impression they were 3"
I definitely need to order some of these as mine have always had a small leak.
2018 Camaro 2SS A8 Redline Edition
BDPhoto519 is offline   Reply With Quote
Old 05-17-2020, 08:46 PM   #9
KingLT1
KingLT1's Avatar
Pipes are 2.75" and the clamps Jcunningham posted are what I was referring to.
Old 05-17-2020, 10:21 PM   #10
JCunningham
Drives: 2017 2SS M6
yep factory is 2.75"
Old 05-18-2020, 03:25 PM   #11
BDPhoto519
BDPhoto519's Avatar
Thanks guys, been dealing with the same exhaust leak for awhile now and its really getting old.
Old 05-19-2020, 08:39 PM   #12
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
Hi BDphoto519, Have you tried those band clamps being suggested? Was the early curve in the pipe a problem for where the bolt needs to tighten on the band clamp?
2016 SS M6
Old 05-19-2020, 09:18 PM   #13
BDPhoto519
BDPhoto519's Avatar
I just ordered them when they suggested them above... Shipping is painfully slow right now, especially across the border to us snowy Canadians!
I think they are going to be tight, but I will trim the clamps a little if I need too and wrap the connections underneath. The little 1" clamps that came with my header kit doesn't even come close to covering the 1.5" relief cuts in the flared pipe end. Ugh
I will post up when I try them out!
Old 05-21-2020, 06:31 PM   #14
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
Thanks hope it works! Ill do the same
2016 SS M6
