Old 05-14-2020, 09:38 PM   #1
Nmolina9239
Nmolina9239's Avatar
Drives: 2018 2SS
275/40/20 Fronts 305/35/20 Rears Work?
Does anyone know if the following will not only fit but not mess with stabilitrak etc?
275/40/20 on 20 x 10 +23 Fronts
305/35/20 on 20 x 11 +43 Rears
Thanks
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
Nmolina9239 is offline   Reply With Quote
Old 05-15-2020, 08:59 AM   #2
Markoz28
Drives: 18 ZL1 nightfall grey A10
I don’t know why ppl go with these sizes. The front is taller than the back and since the beginning of history that has been a bad idea. Plus it look strange.
Why not 285/30 and 305/30? This is stock on the ZL1 and works out great
Markoz28 is offline   Reply With Quote
Old 05-15-2020, 10:23 AM   #3
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I don't think a 275/40/20 will fit under the magride spring perch.
Old 05-15-2020, 10:24 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
No the front will be taller then the rear. You will want to run 315/35/20 in the rear then they will be the same height @ 28.7". Or you could do 275/35/20 and 305/35/30, the rears will be a little taller but within range so it doesn't cause any TCS or Stabilitrak issues. A little taller rear looks better imo.
Old 05-15-2020, 07:48 PM   #5
RuthleSSchevy
RuthleSSchevy's Avatar
Drives: 2016Camaro+1968Chevelle+1954BelAir
275 40 20 rubs on the front fender liner in the footwell area when the wheels are turned left or right. There is no way to clearance this area
"Lead me, follow me, or get out of my way." GGSP
RuthleSSchevy is offline   Reply With Quote
Old 06-20-2020, 11:16 AM   #6
Nmolina9239
Drives: 2018 2SS
What are good tire options for the factory ss wheels, 245/40/20 and 275/35/20? I wanted to get something like the MT ET Street SS maybe? I make just north of 700whp
Old 06-20-2020, 11:23 AM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
King and I both run the Nitto NT555R in 305/35/20 on the stock SS rear tires with Whipple blowers. I think they are better on the street than MT’s in my humble opinion. You could run the standard NT555 on the front if you want them to “match”.
Old 06-20-2020, 02:36 PM   #8
Nmolina9239
Drives: 2018 2SS
@joshinator99, , what size would I have to use for the front if I took your recommendation for the rears?
Old 06-20-2020, 02:41 PM   #9
Joshinator99
Moderator
I'm currently running the stock run flats in the front (245/40/20). But you could easily go a little bigger if you wanted to.
Old 06-20-2020, 03:42 PM   #10
The stock SS setup is also taller in the front (27.7" vs 27.6"), just saying.
OP, have you already bought these tires, or just some 1LE wheels and are currently looking for the best tire sizes? 275/40 will almost certainly hit the spring perch, you can try to avoid that with spacers, but first, what are your actual goals? More traction, better cornering, more sidewall for a smoother ride, better looks, or...?
Old 06-21-2020, 08:40 PM   #11
Nmolina9239
Drives: 2018 2SS
Next year I will look into buying some weld wheels for the drag strip. Possibly even another set of wheels and tires for the street, something smaller then the factory 20's. I think for this year I just want to see the following on the factory SS wheels, non 1le.
A. Whats the biggest tire I can fit on the factory wheels, both front and rear even if i have to do the harness relocation in the back.
B. I believe you have to keep the front and rear tire sizes within a certain height difference from each other? .5" maybe? Can this be changed using hptuners?
C. My goal would be to have tires that handle well on the factory wheels, definitely wider that I can still do a roll on someone if needed.
Thanks
