Old 05-13-2020, 03:50 PM   #1
sworn
sworn's Avatar
Drives: 2019 Camaro SS
WOT, Torque Management pulling timing? Auto Trans
Just curious to hear some opinion's…
Under WOT my 2019 Camaro SS auto seems to pull timing, especially if the tires lose traction. This is with the traction control and Stabilitrak turned off btw.
Am I correct in assuming it's the torque management? Also, you can hear the exhaust pop.
Will a tune be able to get rid of the above mentioned situation?
Thanks in advance!
2019 Camaro 1SS. Crush. Mishimoto Catch Can, BMR Strut Tower Brace, Oracle Side Markers, ZL1 Side Skirts, Blade Spoiler W/ZL1 Addons Wicker Bill, Exhaust Cut Outs, BMR Front and Rear Cradle Braces, Cold Air Inductions CAI. ZL1 Rims 285 Fronts and 305's Rear. Speed Inc Tune PCM & TCM.
sworn is offline   Reply With Quote
Old 05-13-2020, 04:02 PM   #2
NYblack1le
Drives: 2018 1SS 1LE
Sounds like a misfire. Check plugs and wires. Are you hitting the limiter?
NYblack1le is offline   Reply With Quote
Old 05-13-2020, 04:10 PM   #3
sworn
sworn's Avatar
No, not hitting the rev limiter.
Old 05-13-2020, 04:57 PM   #4
Aragorn
Drives: Camaro SS 1LE
Low octane gas?
Aragorn is offline   Reply With Quote
Old 05-13-2020, 05:15 PM   #5
Kerry
Drives: 2019 2SS Camaro
Turning off traction control should keep any limits on power off.
Kerry is offline   Reply With Quote
Old 05-13-2020, 05:57 PM   #6
sworn
sworn's Avatar
I always run premium fuel. The wires all look intact. I'm running cutouts that bypass the NPP muffler with a Cold Air Inductions CAI. The exhaust pops like crazy. No CEL.
Old 05-13-2020, 06:14 PM   #7
NYblack1le
Where are the cutouts located? Does it happen with them closed?
Old 05-13-2020, 06:24 PM   #8
sworn
sworn's Avatar
Cutouts are located before the NPP muffler. That's a good question. They're manual so I'll have to crawl under the car and cap them up. Kind of feel like this may have something to do with it....
Old 05-14-2020, 08:40 AM   #9
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
CAI could be throwing it off if you're not tuned. If you still have the stock intake I'd try swapping that back on to see if it fixes it. I had a 2016 SS with a straight-piped catback 3" exhaust and never had that issue, so I'd be surprised if it was the cutouts.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-14-2020, 03:40 PM   #10
sworn
sworn's Avatar
Very possible. It's the Cold Air Inductions CAI. This one is supposed to require no tune.
