![]() Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
SS 1LE Launch control adjustable?
Is the launch control adjustable on the SS 1LE? I have searched all over the forum but can't find anything on this. I know it has launch control and how to do it. Just not sure if you are able to adjust what rpm you leave at.
Thanks |
The Green Hornet
Drives: 2020 Rally Green 2SS 1LE Join Date: Apr 2019
from this adjustable Launch control is only in SS coupes,ZL1 and ZL1 1LE cars.
CUSTOM LAUNCH CONTROL Models: Camaro SS, Camaro ZL1 Coupe and Camaro ZL1 with the 1LE Performance Package. Custom Launch Control allows the Launch RPM, Slip Target (5%-15%) and Surface Type parameters for Launch Control to be modified. To adjust Launch RPM: • The vehicle must be in Track Mode • Performance Traction Management (PTM) Mode must be enabled • The steering wheel must be straight and the driver door closed • The transmission must be in a gear other than R (Reverse). It will work in P (Park) or N (Neutral) • The parking brake must not be engaged Using the buttons on the right side of the steering wheel, scroll to “Options” on the Driver Information Center menu to select your Surface, Launch RPM and desired Slip Target. For full details and information, see the Camaro High Performance Owner’s Manual Supplement.
XCMKZ4- 2020 Rally Green 2SS 1LE
1100-07/02/19 3100-07/04/19 | TPW 8/5 3400-7/29/19 3800-8/2/19 Built! 4300-8/5/19 4300-8/9/19 delivered to rail yard 4200-8/13/19 Shipped! 5000-8/19/19 6000-8/24/19 She's Home! |
Thats what I was thinking, I'm surprised the SS gets it but not the SS 1LE. Thank you.
![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
That's because the adjustable feature is only available for automatics, and you cannot get an SS 1LE with an automatic (until 2021, that is).
Matt Miller
2020 SS 1LE |
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Not sure that's correct. Customized launch control is only available on the ZL1. Launch Control is avail on SS and up. It is avail on Auto or Manual. At least, that's what my 2017 Manual says. I just checked the 2019 and 2020 HP supplement and it says the same thing. https://my.chevrolet.com/content/dam...supplement.pdf Page 20 in 2017. Page 23 in 2019/2020.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
#6 | |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
This. M6 ss and ss 1le have the same LC.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#8 |
On the topic of launch control: the manual for my 2020 1LE says I need to be in Competitive Driving Mode to use it. But if I just put my car in Track Mode with the main switch on the console, it engages launch control. Do the rest of you find that as well?
Matt Miller
2020 SS 1LE |
