Go Back   CAMARO6 > Members Area > Site Related Announcements / Suggestions / Feedback / Questions
Old 05-10-2020, 02:01 PM   #1
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Deleting old threads I've created
I've figured out how to delete old posts I've made but would also like to delete old threads I've created. I am getting a message I cannot create a new thread as I have hit the limit. TIA.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 05-12-2020, 07:06 PM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Members can't delete threads. You will have to contact a mod to do it and even then they most likely won't.
It's odd you're getting an error message saying you hit a limit. I seen members with a lot more created threads then you.
Mr_Draco is offline   Reply With Quote
Old 05-14-2020, 12:43 AM   #3
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
You're trying to create a thread in the Sponsors Classifieds. Please try the Members Classifieds instead -- https://www.camaro5.com/forums/forumdisplay.php?f=30
Tran is offline   Reply With Quote
