Old 05-08-2020, 08:37 AM   #1
RSFR
RSFR's Avatar
Drives: ZL1
Broke The Race Car
This day didn't quite go as expected...
RSFR is offline   Reply With Quote
Old 05-08-2020, 08:55 AM   #2
ZRacerLE
ZRacerLE's Avatar
Drives: The DSSV Twins: ZR2 and ZLE A10
Just subscribed to your YouTube channel. Hope you guys get everything sorted out.
ZRacerLE is offline   Reply With Quote
Old 05-08-2020, 02:47 PM   #3
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
thanks for sharing, and providing such good details :-)
One question - the rear toe issue that you mentioned - were you able to figure out any solution for that? What do you think about the BMR control arms to eliminate the OEM arms and TYY fasteners to help with this?
Zl1+911 is offline   Reply With Quote
Old 05-08-2020, 03:33 PM   #4
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
Nice to see you're still running that used Callaway Supercharger!
Apparently it's working nicely for you. Maybe you should put the Callaway name back on it.
breakskeet is offline   Reply With Quote
Old 05-08-2020, 04:45 PM   #5
RSFR
RSFR's Avatar
Drives: ZL1
Nice! Thanks!
Haven't figured out what is causing that. The weird thing is, all the bolts are still tight when we check it afterwards. We added BMR toe rods to the car and the issue was still there. We're changing everything out of the rear end, though. We'll see how she does afterwards.
Old 05-08-2020, 05:05 PM   #6
cirpower
Drives: Camaro ZL1
Great channel, subscribed! Thanks for all the info.
I would be interested if the catch can and new seal fixed the issue? Which catch can are you going for?
Did you have to make any changes to fit the 355 ACR tires?
cheers
cirpower
cirpower is offline   Reply With Quote
Old 05-09-2020, 12:03 AM   #7
RSFR
RSFR's Avatar
Drives: ZL1
cheers
cirpower
Awesome! Thanks!
Not sure what brand we're going with. Supposed to go back and test the car on Thursday, so hopefully everything will hold together this time.
To get the 355s to work properly, we moved all the wires out from the wheel well, we removed the fender linings, and we installed BMR toe rods to max out our negative camber.
