Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > CANADA
Old 05-05-2020, 10:04 PM   #1
Lostx403
Drives: 19 SS
Alberta Fuel
New SS owner and now that it’s actually nice enough to drive the car just wondering what other Albertans are running for fuel?
Normally I would be against running ethanol blended fuel but since the only 93 or 94 octane we can get here has it, no ill effect for anyone running the higher octane from Petro or Husky?
Safe to just roll with Shell 91 at this elevation otherwise?
Thanks
Lostx403 is offline   Reply With Quote
Old 05-05-2020, 10:24 PM   #2
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Dunno about SS, but my C7 never had an issue with 91 octane in the short while I owned it, and I definitely had a few WOT runs in before mother natured yanked it away. I imagine SS wouldn't be any different.
Personally I don't think 91 octane will be an issue since it's still an NA car, and I also stopped caring about the whole E0 and E10 thing. Other than the theoretical 3% decrease in gas mileage(which is too little of variance to be statistically significant) there is little to no harm in using it, especially if you drive your car often enough to refuel frequently.
Now, whether or not the E10 fuel makes sense on a macro scale, well that's a whole other discussion.
UnknownJinX is offline   Reply With Quote
Old 05-07-2020, 05:40 AM   #3
Nate_K1500
Drives: 2016 Camaro SS
Shell, coop, Costco only. I personally try to avoid those places that add ethenol to the gas
Nate_K1500 is offline   Reply With Quote
Old 05-10-2020, 11:46 AM   #4
North of 49th
North of 49th's Avatar
Drives: 2018 ZL1 Convertible
I always use Petro 94 if not available it will be Shell 91
North of 49th is offline   Reply With Quote
Old 05-10-2020, 02:47 PM   #5
UnknownJinX
Care to explain why?
I used to do the same but realized there is little to no point. Cars are not lawn mowers, they are designed to take E10 and below.
If anything I think ethanol can help reduce carbon buildup by a small amount. Those E85 engines are usually squeaky clean when torn down.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
Old 05-10-2020, 09:57 PM   #6
Lostx403
Drives: 19 SS
Everything I've googled and after reading older threads on this forum it would seem rolling with 94 is the best bet on account these cars are mapped for running fuel with ethanol in it.
I'm still in the break-in period so I haven't done any overly spirited driving to get a feel of any real difference between when I picked the car up and the dealer filled it with Petro 94 against when I last filled it with Shell 91.
Was more interested in seeing if any folks here in AB have had any issues or more so if 91 is fine with our elevation.
Old 05-11-2020, 09:40 PM   #7
Corbu
Drives: Camaro 2SS
91 will not give you full performance, from what I gather the engine it will retard the timing on 91 Octane. Does it matter for regular driving? Probably not. For track days or full performance Petro 94 is probably a safer bet though.
2017 2SS stock
Corbu is offline   Reply With Quote
Old 05-15-2020, 05:08 AM   #8
Koldunic
Drives: 2018 ZL1 1LE
I used to avoid ethanol too. I must admit I don't know why.
Now I only use Petro Canada 94. Shell 91 when not available.
I asked the question some time ago on the american side of the forum and the answer was between 100% pure 91 octane and adequate mix of gazoline and ethanol at 94, it's better to get the 94.
Koldunic is offline   Reply With Quote
Old 05-15-2020, 06:43 PM   #9
laid_man
laid_man's Avatar
Drives: 2017 Camaro 1SS 6spd Nightfall Grey
I recommend 94 at petro. I’ve run 91 a few times on long trips and it feels like my car loses power it’s noticeable at least to me.
laid_man is offline   Reply With Quote
Old 05-16-2020, 09:10 AM   #10
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Always choose the highest octane.
As stated - the LT1 does just fine with ethanol.
Old 05-22-2020, 01:32 PM   #11
Lostx403
Drives: 19 SS
FYI apparently Calgary has Chevron gas stations now that offer ethanol free 94 octane.
Will check it out for my next fill up.
Old 05-22-2020, 03:09 PM   #12
UnknownJinX
BC has had that for a while so maybe they are expanding. In fact, in BC, only Chevron has 94 octane gas.
Either way, I tried Petro Super 94 and so far I don't notice much, but then again, I am still breaking in and I didn't push my car that hard.
Current:
Past:
Old 05-25-2020, 08:48 AM   #13
2019ZL1Droptop
2019ZL1Droptop's Avatar
Drives: 2019 ZL1
Petro-Canada 94..
2019 ZL1 M10 Convertible
Shadow Gray Metallic
SIGPIC][/SIGPIC]]
2019ZL1Droptop is offline   Reply With Quote
