Old 05-04-2020, 08:35 PM   #1
Yeti6
Yeti6's Avatar
Drives: 2019 1SS M6
Header Install Desperate for Help
I am in desperate need of help. After a week of absolute hell (one problem after another) installing headers on my 2019 Camaro I finally Dropped her down and fired it up, started up after the second push, but the brakes didn't work (almost crapped my pants). Then I noticed the exhaust had dropped down and was about 4 inches from the ground, I had tightened all clamps to 40 lbs, but when I touched the exhaust it was loose. I tightened the clamps like a mofo and they are still loose (now one is stripped and wont move). Are the clamps (speed engineering supplied) just garbage and I need to order some? Anyone have any suggestions on the best clamps to use? Any suggestions are greatly appreciated. Also, has anyone run into "Service Brake Assist" after a header/xpipe install? My car has been down for over a week now... any help is appreciated. The header/xpipe kit with holes for three O2 sensors, do I use all three? Or just the two front ones? Thank you!
2019 Camaro 1SS M6 Summit White
2018 Camaro 1SS A8 Summit White
2010 Camaro 2SS M6 Inferno Orange Metallic
1998 Camaro Z28 M6 Arctic White
1991 Camaro RS A5 Arctic White
1986 Camaro SC M5 Teal Green
1980 Camaro Z28 M4 Bright Blue
Yeti6 is offline   Reply With Quote
Old 05-04-2020, 10:24 PM   #2
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Mega clamps or another brand of band clamps. The speed engineering ones I had on my 4th gen were trash.
Jaxcam02 is offline   Reply With Quote
Old 05-05-2020, 12:58 AM   #3
Baddawg53
Drives: 17 hyper blue 2SS M6
Pictures would be great to help get an idea what's going on. I know on my long tubes I have O2's before and after my cats and an extra for my AFR guage. 5 total on both banks. I had a little trouble sealing some of the joints but nothing like what you're describing ... Some more details would be great ..
Baddawg53 is offline   Reply With Quote
Old 05-05-2020, 01:24 AM   #4
s346k
s346k's Avatar
Drives: like an old lady
the speed engineering clamps are junk. i’d suggest a quality lap joint band clamp, i bought walker clamps for mine. if the exhaust is hanging down that far i’d be looking at the hangers. i had to cut 2 of the hangers off the SE midpipe and relocate them, they weren’t close, at all. the forward most holes are for the primary o2s, the 3rd farther back is for a wideband o2. i put one of the old secondary o2s in it just to plug the hole.
Old 05-08-2020, 03:34 PM   #5
Yeti6
Yeti6's Avatar
Drives: 2019 1SS M6
Thanks guys! I ordered some Magnaflow straps and they worked as they should; the exhaust is nice and tight now.
