![]() Drives: 2019 Camaro SS Join Date: Jan 2017
Battery Voltage? 19 SS
So I noticed my 19 SS with 580 miles on the odo cranked a bit slow this morning.
The car was purchased in Dec of 2019 and stored until March of this year. During storage I used the optional "Camaro" trickle charger. As I was cruising I noticed the volt gauge was about 12.5ish under load. My Camaro is NOT my DD and may sit for a couple days or a week depending on my work schedule and weather. Is the 12.5-12-8,9 reading about normal? I've heard that these batteries have a history of premature failure. Thanks in advance!
2019 Camaro 1SS. Crush. Mishimoto Catch Can, BMR Strut Tower Brace, Oracle Side Markers, ZL1 Side Skirts, Blade Spoiler W/ZL1 Addons Wicker Bill, Exhaust Cut Outs, BMR Front and Rear Cradle Braces, Cold Air Inductions CAI. ZL1 Rims 285 Fronts and 305's Rear. Speed Inc Tune PCM & TCM.
![]() ![]() Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
That volt reading is normal, it'll fluctuate up to 14 and back down as the alternator turns on and off.
Okay, good to know. Thanks!
![]() Drives: 2016 SS 2SS Join Date: Dec 2016
if you have been keeping it on the tender then the battery is most likely fully charged and the volts wont be reading high. These are high compression engines and IMO the starter is just adequate for spinning them cold AND hot. But yeah.. slow starts are normal for this beast.
![]() Drives: 2020 Camaro RS Join Date: Oct 2019
GM has a "Smart" charging system that uses up to 9 different modes (depending on vehicle). It uses these system modes to maintain a proper state of charge (SOC). If you are the least bit old school it's really strange.
Flooded batteries don't handle discharge (deeper cycling) well so older charging systems generally ran high a lot of the time. AGM batteries, however, are very sensitive to over-charging but handle deeper cycling better. AGM batteries also charge much faster (less internal resistance). The smart charging system will charge high (14+) after starting (starting mode, one of the 9 modes) but it won't stay there long at all because the AGM battery charges faster and doesn't like being over-charged. When "cruising" along the charging system will go into "economy mode" to save fuel (alternators use horsepower) and your voltage output will drop lower. There's even a mode where it doesn't charge at all. You may even see an increase in output when decelerating as the system uses the RPMs to increase your charging rate while not impacting fuel usage (kind of like regenerative braking, if you will). So watch your readout for a high number (14+ probably) upon start but diminish relatively quickly. While cruising you likely see relatively low charging rates. The smart charging systems tries to maintain a steady "state of charge" (SOC) by reducing the time spent at high charging and discharging rates. I am not saying your battery is not going bad because sometimes batteries just do so. However, it's likely the reading is in the 12s because your battery is fully charged at the time and the system has gone into economy mode as you cruise along. JMHO No expertise implied or expressed
RWT
2020 Camaro RS, V6, 6MT, Satin Steel 2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray 2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic |
#6 | |
Good to know! Was a bit worried as the car sits for a while.
#7 | |
