Old 05-02-2020, 04:34 PM   #1
Vee-Ate-Kameiro
Drives: 2018 Chevrolet Camaro 2SS
Installing Borla Mid-pipes (#60610)
hi i'm working on installing this system on my 6th gen Camaro SS. I am doing it in my driveway on jack stands and i'm running into what appears to be a fitment issue between the two straight pipes and the X-pipe.
I removed the entire original exhaust system and when putting on the new system i cant get the two straight pipes connected into the X pipe. I can get the straight pipes into the front piece connecting to the secondary cats. I also noticed that the straight pipe has a slight bend at the end. I think thats the end that is supposed to go into the X-pipe and the bend should be pointing downward. Let me know if i'm wrong.
Wondering if anyone else has had this issue and any advice would be greatly appreciated!
Thanks
Vee-Ate-Kameiro is offline   Reply With Quote
Old 05-02-2020, 05:01 PM   #2
oldman
Drives: SS 6 speed of course
I put a 60608 (which is a resonator version of the straight pipe) in a stock exhaust system (all four cats inplace). I had to use two pieces of wood to spread the piping a little and the just slid in place. AFAIK you can't install it backwards because the pipes are only flared at one end.
