Old 05-02-2020, 02:11 PM   #1
mjds
Drives: anything with wheels
Aluminum front brace for v6 and v8 but not I4
In before if it makes the power it needs it, whats the deal with the big aluminum boomerang under the front of the car on the v6 and v8 car I noticed my 4cyl car doesn't have it
Is this chassis brace for the bigger displacement engines? or is it something I can buy and bolt on. I'm curious because guys say if you jack up the car from it and it bends its expensive to replace. what is it?!?!
I've attached some pictures everyone play spot the difference Im sure you'll see what I mean.
mjds is offline   Reply With Quote
Old 05-03-2020, 02:11 AM   #2
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
That's the front subframe. Yours has one too but it looks like it's just steel.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 05-03-2020, 07:29 PM   #3
mjds
in comparison its not even there lol I'm just surprised its so different.
Old 05-04-2020, 04:15 AM   #4
DriftNDraft
Drives: 2020 1SS 1LE M6 was 2018 V6 RS A8
I’ve asked about this brace before. It’s not on my 2018 V6 RS A8 either, but apparently it is installed on the V6 1LE. Would be nice to know if it’s part of the FE3 suspension package and if it will bolt to any 6 gen.
See https://www.camaro6.com/forums/showthread.php?t=561662
DriftNDraft is offline   Reply With Quote
Old 05-04-2020, 08:30 AM   #5
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
This post has the info from GM on which model gets which brace. You're referring to the "front shear panel."
https://www.camaro6.com/forums/showthread.php?t=426710
This is very stiff laterally, but not stiff at all from a bending standpoint (bending load would not be really placed on it while driving). You would definitely NOT want to jack from it.
It's not on the LT V6, but is on the 1LE likely due to the higher cornering loading capability on that model.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
