Old 05-01-2020, 02:12 PM   #1
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Front fire sub?
Anyone running a single 10” front fire sub on the 6 gen coupe?
2004YZFR1 is offline   Reply With Quote
Old 05-01-2020, 05:46 PM   #2
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
All i could find were sealed sub boxes..single10inch box had like 2cub ft..maybe a solobaric12 sealed could use..im using 2x12 skar.. 1c ft per side sealed
2019/LT1 2SS
RLNTLSS is offline   Reply With Quote
Old 05-01-2020, 08:19 PM   #3
2004YZFR1
I just ordered mine, just 1
10” forward fire box. On my last car I used a rear fire. The reason I was asking is they are saying the forward fire sub sounds better since it doesn’t use all of the trunk space. I’ll have to wait till everything gets here and I install it to see the difference.
Old 05-01-2020, 09:28 PM   #4
Trochoidal
Drives: 2017 Camaro 2SS A8
Is this the box you bought?
Old 05-01-2020, 09:42 PM   #5
2004YZFR1
The link didn’t work when I tried to check it. I got one from Zenclouser again. It’s a sealed box. And I bought the Sub Hump harness with the ANC bypass and a LCI-2 to go from the stock Bose amp to my 600w Alpine bass amp with a Alpine type R 4 ohm duel voice coil sub.
Old 05-01-2020, 10:39 PM   #6
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
I've had a rear fire in my last Camaro and it was just sounded deep and messy and on the outside everything that was made out of aluminum or metal just rattled like crazy and it kind of just to me it sounded real trashy.. I got front fire sealed and it sounds immaculate solid base hits.. I had my doubts since I had a 8-in sub with a 2,000 watt amp on it and it sounded great inside but outside it's not a real sloppy..I'm glad I went with the front fire I kind of felt like I should have just got a single 12 with two cubic foot and just get a solar barak square
2019/LT1 2SS
Old 05-01-2020, 10:46 PM   #7
2004YZFR1
That’s the kind of feedback I was looking for. Someone that had heard both. Thanks.
Old 05-01-2020, 11:57 PM   #8
Trochoidal
Yeah that link just wouldn’t work. I found the box. Thanks for the help.
Old 05-01-2020, 11:59 PM   #9
Trochoidal
Hmmm...Two 8’s must be a nice tight and clean sound. I would also believe 2004YZFR1‘s single 10” will also perform well. I’ll keep an eye on this thread.
Old 05-02-2020, 01:13 AM   #10
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Yeah I have my two scar 12s but my next step up is going to be SoundCube or sundown audio I'm still stuck with a 8-in scar and it's a little skar box ported. With an extra battery it stays solid hits battery never goes below 13.5 volts..first system I've ever owned with a spare battery and it's it's a world changer
2019/LT1 2SS
Old 05-02-2020, 09:19 AM   #11
chris227
chris227's Avatar
Drives: 2020 Camaro 2SS
I ran a single 10' front fire in a custom box for about 3 yrs. It sounded better to me. I mainly did it to keep the trunk from rattling as much.
Old 05-02-2020, 01:00 PM   #12
2004YZFR1
Thanks for the info Chris227.
Old 05-02-2020, 02:31 PM   #13
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
This is mainly the same reason why I wanted it let's rattles more boom solid type boom Good luck and I hope you make a great choice that you will enjoy
2019/LT1 2SS
Old 05-03-2020, 02:55 AM   #14
2004YZFR1
Thanks, I'll post some pictures of the install after I get everything. I might just mount everything to the back of the sub box instead of going under the floor support. I think that I could make it still look clean like that. I'm still debating which way to install it.
