New Spec-D Sequential Tail Lights
I just installed the Spec-D Sequential Tail Lights. I love the look, but have concerns about the behavior of the lights during braking. When applying the brakes, (1) the sequential animation turns on, (2) the sequential animation turns off, then (3) the Spec-D brake LEDs turn on. My concern is that this unusual behavior might cause drivers behind me to become confused and possibly hit me. Also, when releasing the brake when the lights are on, there is a delay before the running lights turn back on.
I'm interested to hear others' feedback. I've emailed Spec-D about possibly modifying the behavior of the light, but I've not received a response. Here is a video that I took that shows all of the functions of the tail light: https://youtu.be/ylJBHBvdgJw
Steve-A-Reeno
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Too Mustang for me, but look professional. What part or MD you in? Grew up in South Baltimore Suburbs.
![]() Drives: 2019 Camaro SS M6 Join Date: Jan 2020
I think they look good. I wouldn't worry about the actions, they seem fine! I personally don't think they are as bright as stock tail lights. Hard to see on a bright sunny day. Look at your taillight brightness compared to your 3rd brake light. They do look sharp, and I hope you are happy with them.
![]() Drives: 2016 Camaro RS Join Date: May 2016
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016, those look great.
Steve-A-Reeno
#6 | |
Steve-A-Reeno
#7 |
Hey Steve: Just read your post. I think you made a wise decision! Glad for you. I'm sure you'll find something that works in the future. If I may mention something: When looking for LED lamps you ALWAYS want the LED color to match the lens color. Has to do with light spectrum. For example: White LED behind a red lens with look pink. Put a red LED behind the same lens and see the dramatic difference in brightness and color. This is because the other colors in the light spectrum are blocked by the lens color making red light the dominate spectrum color to that lens. Hope that makes sense. Well anyway, enough with science and stay well!
#8 |
![]() Drives: 2019 1SS M6 Join Date: Feb 2020
As I was watching your video it appeared the right side actually has no sequential function like the left side...At any point of use..{?} EDIT: OK I see that you stated it was off on the right ..On a side note,I don't think the orange tinted lights would be legal here in Pa. and would probably get you wheeled over..
| Tags |
| behavior, custom, sequential, spec-d, tail light |
