Old 05-01-2020, 11:25 AM   #1
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
Trailer Loading Camera
Loading the ZLE on a trailer without a spotter can be a challenge with the limited visibility. I managed to bread off one of the canards even with a spotter. Anybody come up with a simple forward looking camera setup for this? Or perhaps one to mount at the front of the trailer facing the car.
m3bs is offline   Reply With Quote
Old 05-01-2020, 12:19 PM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Sounds like your spotter wasn't doing too good of a job :(
I usually just stick my head out the driver's window and make sure I'm in the right spot relative to the trailer fender on the driver's side when I do it on my own. Can cut it close to the driver side and be OK on the passenger side that way. If not, what about using mirrors on the trailer? I've not personally seen a camera setup for this on a Camaro, but I haven't done much searching either.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-01-2020, 12:31 PM   #3
m3bs
m3bs's Avatar
Agree on the spotter.....
Old 05-01-2020, 04:27 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Mount a Go Pro somewhere and use the app.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 05-01-2020, 05:53 PM   #5
m3bs
m3bs's Avatar
My ancient GoPro won’t do it. Guess it’s time for an upgrade.
Old 05-02-2020, 12:36 PM   #6
JD_
JD_'s Avatar
Drives: 2018 2SS 1LE in Nightfall Gray
+1, great idea. Will be facing this dilemma myself in a couple weeks.
JD_ is offline   Reply With Quote
Old 05-04-2020, 03:34 AM   #7
cdrptrks
cdrptrks's Avatar
There are a few front camera options out there that integrate with the center screen. They are meant for parking assistance but might help with lining up to drive onto a trailer too.
https://www.camaro6.com/forums/showthread.php?t=540420
https://www.camaro6.com/forums/showthread.php?t=500513
Old 06-30-2020, 05:27 PM   #8
Max2075
Max2075's Avatar
Drives: 2004 Z06, 2018 ZL1 1LE
I use my gopro. The video is delayed to the cell phone so you have to be carefull.
Max2075 is offline   Reply With Quote
Old 07-01-2020, 03:29 AM   #9
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Size:  243.2 KBFor an easy fix (and probably more accurate and outside view of the front end), you may also find some 2x4 wood and put them into the stake pockets with a convex mirror attached to it .. I used to put them up front then changed the location to one of the rear left side to load up the car, I don't use it that much anymore and can load the car by my own as I'm used to but it still a piece of mind of course... I'm just lazy
glamcem is offline   Reply With Quote
Old 07-01-2020, 09:47 AM   #10
ICTsccaCamaro
Drives: 2018 ZL1 1LE
I load solo 100% of the time, I stick my head out of the drivers window and watch the left front tire clearance to the trailer side, I also have a wheel stop that I put on the trailer so I know how far to pull up.
ICTsccaCamaro is offline   Reply With Quote
