Old 04-29-2020, 05:55 PM   #1
ride_002000
Drives: 2016 F150
Vibration in steering wheel - could it be wheel bearings??
2018 Camaro 2SS - 34k miles
I bought the car last year in Florida, drove it back to Michigan and put new Nitto NT555 G2 tires on the stock rims the next day. After driving for a day or two I felt a vibration at highway speeds (70+mph), I took it back to discount tire and they said my one wheel was slightly bent. I had them remount and road force balance and I left. I drove it like that for about a month and then picked up some Z28 replica wheels that were a week old. Had the same tires mounted and still have a vibration. I had them rebalance and still the same. Now do you think it's something wrong with the suspension? Wheel bearings maybe? Or Defective tires? Want to get this resolved. One of these days my buddy is going to swap wheels/tires from his 1LE to see if that rules out the tires/wheels but wanted to see if any of y'all have had an issue.
ride_002000 is offline   Reply With Quote
Old 04-29-2020, 06:03 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
whens last time you had alignment done?
Old 04-29-2020, 06:06 PM   #3
ride_002000
Drives: 2016 F150
Had it done last June, right after getting the new tires
Old 04-29-2020, 06:16 PM   #4
Jb54
Drives: 2019 Camaro SS M6
I don't think you have a wheel bearing issue, due to year of your car and miles stated. 99 times out of a 100 it is your tires or wheels that is the problem. I would have all your wheels checked for trueness and use use better quality tires. Also, have you thought about a drive shaft issue such as u joints or a carrier bearing perhaps.
Jb54 is offline   Reply With Quote
Old 04-29-2020, 06:24 PM   #5
MarkSS1958
MarkSS1958's Avatar
Drives: "19" 2SS 4xBlack "16" Ram 4x4
Maybe one of your wheels threw a balance weight .
MarkSS1958 is offline   Reply With Quote
Old 04-29-2020, 06:32 PM   #6
ride_002000
Drives: 2016 F150
I thought Nittos are a quality tire? I doubt they threw a weight since I had them rebalanced twice. I will get the wheels checked. Didn't think it was a drive shaft or carrier bearing since it's in the steering wheel
Old 04-29-2020, 07:34 PM   #7
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Every tire manufacturer can have issues. I once has a similar issue with a new F1 Supercar tire on my C5 Z06, ended up being a steel belt in the tire was just slightly misaligned. Got a replacement tire and it was gone.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 04-29-2020, 08:03 PM   #8
ride_002000
Drives: 2016 F150
Yea I understand all tire manufacturers can have some bad tires go out, how does discount tire determine if the tire has a bad belt or is defective?
Old 04-29-2020, 08:49 PM   #9
MrChrisLS3
Drives: 2018 1SS M6
I read it like this, you drove the car from Florida to Michigan without the issue. You put new tires on it, and now there is the issue.
I personally would highly doubt that something like a wheel bearing, or shaft balance, or any of those hard parts would make that trip without issue, then suddenly give out. Possible, maybe, likely not really. Unless there were an event, pot hole, curb, something like that.
New tires, like new anything else can be defective. The steel belts out of whack, flat spotted, stuff like that. It may not show up on the balancer, but put the weight of the car on it, and there it is.
How do you find out which tire it is? I do not know, perhaps Discount Tire has a way to check for that. If they sold you the tire, and it is defective, Nitto covers them, so no skin off their back to replace it.
MrChrisLS3 is offline   Reply With Quote
Old 04-29-2020, 09:19 PM   #10
Wierd Harold
Drives: 2017 2lt rs
You said it's in the steering wheel?There you go , it's in the front tires swap the front of your buddies,one at a time.
Wierd Harold is offline   Reply With Quote
Old 04-29-2020, 09:33 PM   #11
ride_002000
Drives: 2016 F150
Thanks guys, I will do some troubleshooting with my buddies wheels/tires
Old 04-30-2020, 09:57 AM   #12
JT58
Drives: Former 2016 Camaro 1LT
Have heard about this problem and also experienced it many times. It's usually almost always wheel balance. It could be that the tires/wheels were not balanced properly from the start (most likely) or the wheel is bent, or tire out of round. Usually more weights can take care of the bent or out of round issue although a good shop would let you know.
I would check tire balance- not all shops can balance tires good, or it might have been a new guy not properly trained.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 04-30-2020, 10:44 AM   #13
rspitler
rspitler's Avatar
Drives: 2017 SS Convertible
Maybe a dumb question, but isn't the steering on the Camaro electronic? Meaning there isn't a steering column per say. So how would any kind of wheel/suspension issue transfer through the steering wheel? Wouldn't you get those type of things through the seat or somehow?
Just asking...
rspitler is offline   Reply With Quote
Old 04-30-2020, 11:32 AM   #14
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Just asking...
Camaros have electric steering assist. They still have a traditional column and rack and everything, it's just an electric motor providing the assist instead of a hydraulic pump.
@ OP, did the vibration go away after the road force balance on the OE wheels? Did you get the road force and balance both done when swapping to the Z28 reps? If you could balance the vibration out then it came back then I'd just suspect a bad balance job when the tires got mounted on your new wheels. If not, it could be an issue with the tire itself as others have said.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
