Old 04-29-2020, 06:43 AM   #1
Lobster catcher
Drives: 2017ss camaro convertible redline
Rear bumper covered with black exhaust
After every ride I have to wipe the exhaust spatter off the back off this beautiful white camaro.I have the exhaust set in track mode also.I wouldn’t think this would be normal or is it
Lobster catcher is offline   Reply With Quote
Old 04-29-2020, 07:21 AM   #2
Jeb114
Jeb114's Avatar
Drives: 2021 300
Black suet on the rear bumper means the car is running to rich. Too much fuel in the mix. check for codes in the PCM
Jeb114 is offline   Reply With Quote
Old 04-29-2020, 08:39 AM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Are you positive it's only stuff coming from the exhaust? Easiest way to tell is to wipe down the inside of the exhaust tips and look for buildup there. Also, if you drive at WOT a lot you'll get a lot of extra soot coming out because you're forcing the car to run rich which is normal.
White shows everything, even driving on "clean" roads there's still enough dirt/dust getting picked up that I get a light coating on the rear bumper after a light drive. I assume aerodynamics don't help with that either since it's probably swirling the air behind the car a bit.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 04-29-2020, 11:53 AM   #4
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
The rear of mine gets dirty first. I've always assumed its an aerodynamic effect of the wind coming around, over and under the car causing dirt to swirl up and stick the the rear area. I've not noticed the dirt to be just exhaust soot. Instead it looks to be mostly road grime on mine.
476 rwhp/440 rwtq (sold)
Old 04-29-2020, 12:35 PM   #5
Yellow Beast
TD
Yellow Beast's Avatar
Drives: 2017 2SS, 2014 Mercedes C300
Same thing here. I'm thinking its either the exhaust spatter or the rubber coming off my stock Goodyear run flats. Is anyone having this issue with different tires?
Yellow Beast is offline   Reply With Quote
Old 04-29-2020, 02:24 PM   #6
Racerman27410
Racerman27410's Avatar
Drives: 2016 SS 2SS
this time of years its probably just blowing condensation out when you first start the car in the mornings.
Racerman27410 is offline   Reply With Quote
Old 04-29-2020, 02:34 PM   #7
14Black1LESS
14Black1LESS's Avatar
Drives: 2014 2SS/RS/1LE
Get a black car and you will never have to worry about seeing it.
14Black1LESS is offline   Reply With Quote
Old 04-29-2020, 06:07 PM   #8
Lobster catcher
Ok thanks for the comments I have been running her quite hard in track mode maybe she’s a little rich .I have the darker dust I figured that normal but the black specs are definitely exhaust.I will look at after the wife takes it she’s not so heavy on the accelerator lol
