Old 04-26-2020, 02:51 PM   #1
shaftwhy
Drives: ZL1 Finally
Drive 1 mile to tire shop with complete flat tire
Got a flat tire, it was so bad that it couldn't be inflated to any pressure, not even with tire repair kit, not even 1 psi.
Car is at home, tire shop is 1 mile away from my home. If drive slowly to tire shop for 1 mile, is it going to damage wheel?
I probably haven driven 1 mile already to home, after noticed low tire pressure, before tire pressure dropped to 3 psi, or is the wheel already damaged?
shaftwhy is offline   Reply With Quote
Old 04-26-2020, 03:09 PM   #2
Yves ZL1
Yves ZL1's Avatar
Drives: Canadian 2019 BLACK ZL1
I don’t think the wheel is damaged... moreover with constant pressure in it but the tire maybe hasn’t appreciated ...
Just a question
What is thé alert for a tire Low pressure ?
Could you tell me with précision thanks ?
Mine is being french-homologated and thé guy told me there was an alert but couldn’t tell me what... just it was a red car picture turned on two Times and no more ...I thought it could be a tire pressure
Yves ZL1 is offline   Reply With Quote
Old 04-26-2020, 03:15 PM   #3
TWG1
TWG1
Drives: 2019 Camaro ZLE
Bad idea. If you can’t get a single PSI to hold, you shouldn’t drive it. ~700 rotations is plenty to cause irreparable damage. Recommend removing rim, removing wheel weights (use dental floss) and bringing it to them separately. If you don’t remove wheel weights yourself, they’ll do it for you...With a screwdriver, chisel, etc, and take your powder coating with it.
2019 ZLE M6
2019 ZL1 A10 (Sold)
1967 Jaguar XKE Series 1 Roadster
2021 F150 Powerboost (on order)
TWG1 is offline   Reply With Quote
Old 04-26-2020, 04:15 PM   #4
Chris 2018 ZL1 A10
Drives: Chevy Camaro ZL1
Uh, aren’t these run-flat tires we’re talking about? There shouldn’t be a problem driving a short distance (<10 miles) for repairs.
Chris
Chris 2018 ZL1 A10 is offline   Reply With Quote
Old 04-26-2020, 04:23 PM   #5
Badmojo
aka BeastZL1
Badmojo's Avatar
Pull the wheel and take the tire to them to get fixed?????
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 04-26-2020, 04:49 PM   #6
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
If it was an absolute emergency, like you're on the side of a 4 lane highway, yes, you could drive it there and risk some damage. But this is no emergency. You have time. Lift the car, take the wheel off, remove the weights as said, and take it to the shop for new rubber. Not worth the risk whatsoever.
Old 04-26-2020, 04:57 PM   #7
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
The ZL1 and SS/1LE performance tires aren't run-flat tires.
Old 04-26-2020, 05:07 PM   #8
Mark114
Mark114's Avatar
Driving a damaged tire risks the possibility that the tire will rip or shred and potentially cause damage to the suspension and/or body in addition to the wheel damage. If you haven't already damaged the wheel then I wouldn't risk more damage driving on a flat tire. If you do have wheel damage then you might want to have it checked before you put a new tire on it.
Your 3/36 warranty may have some roadside assistance coverage with the dealer that will help you. The ZL1 wheels are pretty expensive to replace. Even if you don't have roadside coverage it will be less expensive to use Uber or a taxi than to replace the wheel. Or call the tire shop to see what they'll charge to come to you. Also call ahead to make sure they actually have a replacement tire before you make the trip. Good luck!
Old 04-26-2020, 05:11 PM   #9
AZIROC
Drives: '86 IROC-Z '18 ZL1
Nope. You will screw up the wheel PDQ.
Your best bet is take the wheel off and have the tires shop fix it.
Old 04-26-2020, 05:22 PM   #10
MrChrisLS3
Drives: 2018 1SS M6
Agree 100%. The thing I might add is that even if you cannot remove or transport the wheel to the shop, it would still be cheaper to have a flatbed tow it there than replace a wheel. And definitely call first, it is highly unlikely they will have that tire in stock.
MrChrisLS3 is offline   Reply With Quote
Old 04-26-2020, 05:48 PM   #11
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Mobile tie repair - or remove wheel and uber it there ?
ing for grip.
http://www.motorsportsne.com/
Old 04-26-2020, 06:22 PM   #12
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Late to the party, but do not drive it. Period.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 04-26-2020, 07:12 PM   #13
Alain
Alain's Avatar
why would you drive that thing anywhere on a flat tire after you managed to get it home?????
just take the wheel off man. you don't know anyone who would give you a ride to the tire shop and back? a neighbor??
2018 ZL1 1LE/Red hot
Old 04-26-2020, 07:39 PM   #14
Chris 2018 ZL1 A10
Mark,
You are SO correct. I traded my SS which had RF’s in for my ZL1 two years ago mistakenly thinking it had the RF’s. Guess I should consider buying an extra can of sealant. 😁
