Old 04-25-2020, 09:36 PM   #1
A-A-RON
A-A-RON's Avatar
Drives: Chevrolet Camaro ZL1
Added LUMBAR support to my ZL1 Recaro Seats
I already did the seat recline mod, so now its time to really step it up. Im in the process of adding LUMBAR to the seat. Here is the progress so far. These are manual lumbar adjusters which I have cut and modified before making a cross brace and getting it inside the seat.
I went with the manual lumbar because there is hardly any room in or under these seats for bladders, motors, or switches that I was comfortable working with. Also, because I didn't want to worry about bladders deflating or leaking.
I still have some finish work and mounting for the adjuster knob.
Please see the video links to see the lumbarbi n action, as it's hard to see the support in pictures.
Check out my other posts with my other custom ZL1 projects.
Thanks
https://youtu.be/7XSJyrKHnIw
https://youtu.be/pUzLgMpRtJc
A-A-RON is offline   Reply With Quote
Old 04-25-2020, 11:07 PM   #2
URBAN LEGEND
URBAN LEGEND's Avatar
Nice work, creativity and imagination.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 04-26-2020, 07:09 AM   #3
Marty31
Marty31's Avatar
Drives: 2019 ZL1 A10
Nice work.
Marty31 is offline   Reply With Quote
Old 04-26-2020, 07:43 PM   #4
A-A-RON
A-A-RON's Avatar
Progress made today on the bracket. Just a couple more details to finish up and then upholster it and I'm finished with the Driver's side.
Old 04-26-2020, 07:47 PM   #5
A-A-RON
A-A-RON's Avatar
All riveted in place and the back is all sealed up. Cant even tell its in there.
Old 04-27-2020, 09:18 AM   #6
DFW_Muscle
Drives: 2018 Chevrolet Camaro ZL1
Wow...well done!
DFW_Muscle is offline   Reply With Quote
Old 04-27-2020, 12:17 PM   #7
HoodCheck
HoodCheck's Avatar
Drives: 2018 ZLE (M6/hyper blue)
Sweet. I've been thinking of the recline fix too, as I can't get comfortable in the seats without them reclining a bit more. Was it difficult to do? I've read the walkthrough and it looks like a bitch to do...or at least easy to screw up the seat.
HoodCheck is offline   Reply With Quote
Old 04-27-2020, 02:00 PM   #8
A-A-RON
A-A-RON's Avatar
Recline mod isn't bad. Just be prepaired to possibly go through a couple drill bits if you dont have some good quality ones.
Be sure the seat is fully reclined, all the way down, and all the way forward before disconnecting the battery. Then use the upper seat latch to pull the seat back forward. That mod made a huge difference in itself. Take your time undoing the seat covers and digging out the buried zippers on each side(they are tucked up in the foam padding).
The back cover flap has a hidden clip that makes it look like a seam, but its where the back attaches to the seat bottom(see red arrow #1).
Drill out the welded pin on each side of the seat(red arrow #2).
Old 04-27-2020, 03:41 PM   #9
z28pat
z28pat's Avatar
Drives: 2002 z28, 2023 Zl1
Great work ! Where did you get the manual lumbar supports from ?
z28pat is offline   Reply With Quote
Old 04-27-2020, 04:22 PM   #10
A-A-RON
A-A-RON's Avatar
Ebay. They're actually for a 2005 Ford Excursion/Expedition. GM ones were too pricy to TRY this on($300). They fit just right. Only made 4 cuts to the metal slides. Had to fabricate a cross bracket too, but they will serve the purpose just fine.
Old 04-27-2020, 09:36 PM   #11
HoodCheck
HoodCheck's Avatar
Thanks man!
Old 04-28-2020, 03:35 AM   #12
A-A-RON
A-A-RON's Avatar
Driver's Side is now finished. Works perfectly and turned out exactly how I envisioned. Bracket was riveted in place after a layer of foam and covered with leather. I cut the front cushon cover and tucked the small section under so I could attach the bracket and then secure the cover.
Old 04-28-2020, 01:36 PM   #13
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Hey Ron, you have something you could sell to members on the forum! Design a kit form type of deal with detailed instructions for a price.
Old 04-28-2020, 03:41 PM   #14
A-A-RON
A-A-RON's Avatar
