Old 04-24-2020, 10:43 PM   #1
Chris 2018 ZL1 A10
Drives: Chevy Camaro ZL1
LT4 fuel, oil and coolant system questions
Gentlemen,
I’d like to learn more about the systems in my 2018 ZL1 A10.
Fuel:
1. After fuel has been sent via electric fuel pump from the tank to the engine, is there a secondary fuel pump to significantly boost fuel pressure to ensure proper spray pattern in the cylinder? Is the secondary fuel pump electrical or mechanical?
2. Considering my car doesn’t get driven much, does the fuel system have the capability to purge water from the tank?
Oil:
1. Is the oil pump still mechanically driven off the camshaft (like my L98 was) or is it now electric?
Coolant:
1. Does the SC have its own isolated cooling system that uses the same coolant as the engine?
2. The eLSD has a HX inside, is automatic transmission fluid used to cool the differential fluid?
3. If equipped with a 6M, does it too use transmission fluid to cool the eLSD?
Thank you for your responses,
Chris
Chris 2018 ZL1 A10 is offline   Reply With Quote
Old 04-26-2020, 07:27 PM   #2
Alain
Alain's Avatar
great questions. subscribing for answers.
2018 ZL1 1LE/Red hot
Old 04-26-2020, 07:58 PM   #3
20Bluezl1
same here
Old 04-26-2020, 08:25 PM   #4
Chris 2018 ZL1 A10
Thanks fellas,
A lot has changed since my 1989 L98 equipped C5 Corvette days.
Old 04-26-2020, 08:42 PM   #5
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
The high pressure fuel pump is mechanical.
The oil pump is mechanical and is driven off of the crankshaft.
The intercooler coolant system is separate from the engine coolant system.
7LitreC5 is offline   Reply With Quote
Old 04-26-2020, 09:34 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
transmission fluid cools the eLSD in both the manual and automatic transmission equipped cars. Of course, the 6 speed manual also uses automatic transmission fluid (not gear oil). The A10 requires a special ULV fluid, however. You cannot fill the intercooler circuit without a special setup unless you purchase an aftermarket intercooler reservoir by a company such as Cordes or ADM (recommended). Purge water from the fuel tank...nothing I'm aware of in that respect.
Old 04-27-2020, 12:19 AM   #7
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Originally Posted by Chris 2018 ZL1 A10 View Post
Gentlemen,
Fuel:
Oil:
Coolant:
Chris
F1: The HPFP (high pressure fuel pump) is mechanically driven by the cam shaft and sits in the valley of the engine, supplying ~2500-2900 psi to the injectors.
F2: No.
O1: It's mechanically driven off the crank.
C1: Yes the SC has its own isolated coolant loop with it's own electric pump (the SC loop does not have an easy-user-serviceable fill port) and yes it uses the same 50/50 dexcool that the engine uses.
C2: Yes.
C3: Yes.
