Old 04-24-2020, 12:00 AM   #1
Beto6.2
Drives: ZL1
What's the best mild cam to go with??
2018 auto Zl1
Currently have
- High Flow Cold Air kit
- Upgraded Harmonic Balancer
- Lower Pulley Upgrade
- High Strength Supercharger Belt
- Stainless Steel Longtube headers
- New set of Spark Plugs and Spark Plug Wires
- All necessary gaskets, fluids(Royal Purple)
- Professional assembly & installation
- Custom engine control module reprogramming
- Chassis Dynamometer Report
- E85
I want a good mild cam. Not my daily driver what would you guys recommend thanks in advance
Beto6.2 is offline   Reply With Quote
Old 04-24-2020, 08:27 AM   #2
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Originally Posted by Beto6.2 View Post
2018 auto Zl1
Currently have
- E85
Who’s package did you just quote? That’ll help the recommendations.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 04-24-2020, 11:00 AM   #3
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
That appears to be Vengeance Racing's lingo. Even if not, VR specs a very good camshaft, few shops probably have more built LT4s on the road than them. Their stage 3 LT4 cam is a bad mofo and have heard great things about it.
They have a drivability video up too if you search.
Old 04-24-2020, 11:37 AM   #4
Markoz28
Drives: 18 ZL1 nightfall grey A10
I’m running a Cammotion stage 3. It does nick a bit at stops. Other than that it’s smooth running and make incredible power.
Consider having the stock SC ported while your at it. Should be well over 700whp
Markoz28 is offline   Reply With Quote
Old 04-24-2020, 12:37 PM   #5
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
It's going to require a tune, may be best to ask the tuner what they recommend.
Rlhay2 is offline   Reply With Quote
Old 04-24-2020, 02:24 PM   #6
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
I'll make this simple.
https://www.texas-speed.com/
speedraider is offline   Reply With Quote
Old 04-28-2020, 04:44 PM   #7
Beto6.2
Drives: ZL1
already have those items installed i want feedback on a good mild cam
Old 04-28-2020, 04:48 PM   #8
Beto6.2
Drives: ZL1
I've heard of them and cam sounds nice i like that! Was told that if i go with a big cam i have to get a upgraded converter. Does head porting make a difference on boosted cars?
Old 04-28-2020, 04:50 PM   #9
Beto6.2
Drives: ZL1
Nice do you have any videos so i can hear it? And yeah i might do that are your heads ported?
Old 04-28-2020, 04:58 PM   #10
Beto6.2
Drives: ZL1
I've searched the website before good products i'm doing homework on either doing a mild cam or big cam? Also heard head porting isn't required on boosted application is that true or not?
Old 04-28-2020, 05:00 PM   #11
Beto6.2
Drives: ZL1
Yeah more homework to do lol so i can narrow my selection soon. Is head porting required for a boosted car? I know it helps a lot on a N/A car so i don't know if i should do cam only with support mods or heads/cam?
Old 04-28-2020, 05:04 PM   #12
Can'tHave2MuchHP
Drives: Fast
You will not need a converter upgrade for the VR III cam or nearly any of the cams out there. Boosted cars don't like or need super huge cams or you waste your boost by sending it right out the tailpipes. Cam grinders know that these days and good shops like Vengeance, Texas Speed, RPM, etc. spec cams that are just right. The "Big cam/mild cam" choice is made simple: you can have both. Call Texas Speed, VR, RPM, Weapon-X, Speed Inc, CMS, GP Tuning, CPR, etc. or any of the other dozens of good LT shops out there and talk to them. They will get you exactly what you want. Very little tradeoffs necessary.
Yes, you can get the LT4 heads ported and it's worth 20-40 HP I'd say on average. If you're doing a cam and pulleys, you should get the heads ported. Maybe port the blower/snout while you're at it.
Texas Speed can handle your heads/cam needs. Kong Performance can handle your blower/snout porting. Call them up and get it done.
Old 04-28-2020, 05:36 PM   #13
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Call CamMotion and get something ground for you, as opposed to getting pushed into a cam that isn’t really want you want.
Joshinator99 is online now   Reply With Quote
Old 04-28-2020, 07:30 PM   #14
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
This is what you are looking for.
https://briantooleyracing.com/btr-ca...242742156.html
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
