![]() Drives: Chevrolet Camaro Join Date: Aug 2019
2016 Camaro SS Aftermarket ZL1 Wheels Help
Hello Folks,
So I am in the process of purchasing some aftermarket ZL1 wheels. I found a great deal on Set of Four. Will this be a good setup for my 16SS? Any recommendations for tires size? 20" fits Chevrolet - Camaro ZL1 Wheel Replica - Black 20x8.5/20x9.5 SET FRONT WHEELS: Size: 20x8.5 Offset: 35.0 REAR WHEELS: Size: 20x9.5 Offset: 40.0 |
Front wheel offset is 10 higher than the factory SS wheel, which is far from ideal, but should work if you really want the deal. Rear is certainly fine, "almost OEM", heh.
As to tires, I would only go up to 255/40/20 in the front and 285/35/20 in the rear, or maybe 295/35/20 with a relatively narrower tire (e.g. Nitto or PS4S). Some members here run 305/35/20 Nittos in the rear on stock wheel; for that, relocating the main body harness behind the wheel well liner is recommended (several threads on the subject, search for "relocating wire harness").
Great, thanks for help!
